Question about LG Televison & Video
Our 60inch lg plazma after being off for a few hours flashing strips apear across the screen until it warms up and is ok again
  • juleenb Jun 29, 2009
    The colours are yellow and red across the screen
    Sergeant:
  • 322 Answers
Try changing the bulb of the projector.
Posted on Jun 29, 2009
  • 52 Answers
There may be a problem. What color are these strips that appear across your plasma TV?
LG TV 39LN5300 - What is normal voltage at LED connection to power supply?
ok so the problem is not with the power suppkly it is with the leds inside the panel they are in strings and usually only a few of them are your problem see the link for led prices http://www.shopjimmy.com/auo-t390hvn02-2-led-strips-8-strips.htm
Feb 16, 2018 | LG Televison & Video
My 42LD450 won't stay on! It turns on for a few seconds and works fine, then the screen flashes then comes back on, then flashes again after a couple seconds, then turns off. Rinse and repeat. Tried...
I hope that you can use the warrantee.
Otherwize, it must be possible to repair it with a fried comfortable with electronic because the problem is not permanent. This kind of problem is usually an old capacitor or a bad connection (soldering).
It would be important to check if changing the ambiant temperature fixes the problem. (I.E. move it to the seller for 2h and try..)
Regards,
Jul 10, 2011 | LG 42LD450 42 in TV
Hello, When I set my AC unit to "Heat" and turn it on, the air will come out warm, then after a few hours the air starts to come out cool. To make it warm again I need to set the...
It sounds like you have a heat pump. When you first turn on the system the heat strips will come on and produce warm heat (referred to as supplemental heat strips), as temperatures rise the heat strips will turn off and the "A" coil will just exchange heat to maintain temperature thus conserving energy. . Initially the temps will be around 125 degrees at the register, and drop down to about 105 after the strips turn off.
On some TXV controlled outdoor condensing units the Thermostatic Expansion Valve will stick in the cool position and require replacement this will cause this symptom. It takes several hours to do and requires a licensed technician to do as it involves recovery of refrigerants. I hope this helps
Feb 17, 2011 | Heating & Cooling
Powering up problem with my lg flatron plazma tv
Those lights are a code. I don't know which TV you have, exactly. But the manual will tell you what the light code indicates and what to do about it.
Oct 16, 2017 | LG Flatron L1919S LCD Monitor
Blank Screen
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-4 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO markusmaritz@yahoo.com I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 and i amafrikaans BUT PLZZZ RATE ME
Dec 19, 2008 | Sony Playstation 3 (PS3) Console
Sony dsc-w50 flash going off before or after shutter has opened and closed
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and
Jan 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Thick color lines on screen
Hi ,Sorry, this is not a solution. I have a question about your line. Is it transparent? (can you see through if the picture is bright)Does it remain there all the time if you change inputs? My LG 42" just had a blue transparent line appear on the right side of screen. Tried a few trouble shooting things w/ no change. About 1 hour later it went away. Did you find a solution and what was it?
Sep 05, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
27 people viewed this question
