Question about Behringer EUROPOWER EP2500 Amplifier
No. You said you can fix anything but I can't
No. You said you can fix anything but I can't even get you to take my question. This is a con of some sort. We have a Behringer Eurodesk MX9000. The solo light comes on and cancels everything. Sometimes it comes on when I turn the board on sometimes it will run for more than 2 hours before it comes on. When it is not on it works fine. I talked to someone at Behringer and they said they had never heard of this problem and did think the board could do that. They want $70 an hour to look at it. That does not include shipping.
Can you help me?
  • Behringer Master
  • 5,603 Answers
I will venture a guess that the solo light and loss of output is some sort of power supply issue, that is the solo light is a symptom, not the cause. Check the DC bias out of the outputs. If you find much, you certainly have a power supply problem.
The symptoms of time delay before happens is indicative of a warm up or heat problem.
As a test, try to keep it extra cool.. put a fan blowing on it and see if it lasts longer.
The other possibility is a crack in a board or a bad solder joint OR contamination. Behringer equipment does NOT survive spills of liquids into it.
Posted on Jul 31, 2009
  • 4,234 Answers
Your posting here seems to be the middle of an existing conversation. I'd like to help, but I'll need a bit more info. Can you describe how you have this connected to the system please?
It seems a bit odd that a Solo indication would cut off all output as that is usually a feature to allow you to hear the channel without it being sent to the mix. Is there a solo option for the mains?
Any information that you can provide that details what happens and how you are connected would help. Also, is there a pattern at all for when this occurs? In other words, is this more likely to happen after the unit has been in use for a long time or less likely?
Thanks,
Dan
Posted on Jun 29, 2009
Replaced the power supply/backlight inverter board and T-con boards on my Samsung 37" TV Seems worse than before
hi this is usually is a tcon board fault, but it can also be a bad panel, if it's flashing could a mainboard fault thanks
shaun
Feb 27, 2017 | Samsung Televison & Video
My LCD TV bravia model kdl-37v4000 is shown picture nagatively, which part of componend to be changed. If can be to fixed without service man. Where I can buy and how much the cost will come.
You have to change the t con board of the tv. Even after replacing the t con (added image of the t con )board the problem exist the you have to change the lcd panel. What ever it is you have to change the t con board to confirm.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Tcon
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Nov 19, 2015 | Televison & Video
My TV has vertical lines
hi,
Probably the t con board is faulty. first you have to check is there is any bad contact in the connections on the t con board. Remove and reconnect all the connections on the con broad. if the problem exist even after that you have to go for a new t con board . in some tvs 32 the t con board is not replaceable as it is integrated to the lcd panel.
check the video it will help you to identify the t con board
www.electro-medical.blogspot.com
Sep 25, 2015 | RCA Televison & Video
My sanyo dp42849 screen still has a picture but it has turned white. What is the problem and how do I fix it?
Sep 25, 2015 | Sanyo Televison & Video
How can i fix my 40" Element tv?
it could be the t-con board going. or the screen connector ribbon is lose. or even just the connection cable to the t-con board. if you push gently around the edge of the screen if the pitcher gets better or worse then its the screen connections. sometimes can be fixed with cracking the cable or slightly heating the area and packing, but this is with the led screen panel out. but would think its more a t-con board filing.
Feb 13, 2018 | Element Electronics FLX3210 32 in. LCD TV
No Pitcher
its the t-con board if the backlight is coming on and there is sound then the t-con board is faulty. this is the board on the back of the screen has a cable going to it from the main av board. replace with same part number only. this has to match the screen.
Jul 15, 2017 | Sony BRAVIA® KDL46SL140/91 46 in. HDTV LCD...
Hannspree 28 Inch Lcd Tv Model Number HSG1075
Check its Chroma section circuit for fault. Most possible cause is damaged chroma IC.
Aug 09, 2012 | Hannspree Televison & Video
Vertical band on screen
If it is small like pencil thin and looks like someone used a magic marker to draw the line, the panel has failed and needs replaced this is uneconomical to repair even for a do-it-yourselfer. If it is wide across, it is most likely a t-con failure or lvds cable failure. If the tv is in warranty get it to a authorized service center. If not your best bet is the t-con and to replace these parts usually needs the serial number as well as the model number to get the correct version of t-con for your tv. If you sent this to a shop for repair and it turns out to be a t-con the repair may cost around $200.00 - $300.00 to fix. If it is the lvds cable it will cost less to fix.
Oct 23, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Air con not cooling
If you can vacuum out the filter or wash it out that might help.
Check this web site:
http://www.hometips.com/home_probsolver/hps06/02_ac_andheatpumps/hps_ac02.html
Feb 11, 2009 | Kenmore 75051 Wall/Window Air Conditioner
Behringer EUROPOWER EP2500 Amplifier Logo
253 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
