Question about SanDisk Sansa e260 MP3 Player
Sansa won't let me delete songs manually
My player is is MSC mode and it picks up on "my computer" but when i go to my player it says there are no songs on the player. Same thing happens when i try to delete the files manually in Windows Media Player.
HELP
    Novelist:
  • 166 Answers
Format it and see if that works.this will delete all of your songs so back them up first.if you want instructions on how to format email me at gamecrazy944@yahoo.com
Posted on Jun 30, 2009
I have down loaded a bea to delete other songs -also I have one auto book I am not able to delete
What is a 'bea?'
One way to delete songs (and maybe books) easily is to it through your computer, while the Sansa is tethered;
1) Download the Sansa Clip manual. Here's a link;
http://www.sandisk.com/media/327475/CLIP+_UM_0809_ENG+090309.pdf
2) Put your Sansa in MSC (Mass Storage Class) mode.
Go to Settings, then USB Mode. Select MSC mode.
3) Tether the Sansa to your computer. It will look like a USB flash drive.
4) Delete or add Music, or Books.
You can use Windows Explorer to look through the directories on the Sansa, and delete files directly, as you would on a USB Flash drive.
Special Note on Audio Books--
Get an extra memory card, 4 to 8 Gb should do, and use this as your destination for audio books. If you have a book that will not delete, you can pull the card and re-format it, while leaving your songs intact on the main memory.
If you cannot delete the book through the computer or by menus on the Sansa, you may have to re-format your main memory. Hope that helps!
Nov 17, 2011 | SanDisk Sansa Clip MP3 Player
I have a sansa e250 and i have 400 and something songs they all used to play. now only a few of them play what happened
Freezing up while playing songs Check and see if there is a boot file in any of the folders on the player use the Explorer to check Check both MTP and MSC modes and unhook your player
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Jun 26, 2010 | SanDisk Sansa e250 MP3 Player
I got a problem with my mp3
Transfers onto the m240 can be done in 2 USB connection modes:
MTP mode: Media Transfer Protocol using software, e.g. Windows Media Player 10 or higher.
MSC mode: Mass Storage Class using Windows Explorer, looking in "My Computer" viewing the player as a removable disk.
Typically, songs put onto the player in MSC mode can not be viewed in MTP mode and the other way around.
Switching to MSC mode in the player's menu:
Look in the player under Settings Menus > USB > select MSC for using the "copy and paste" or "drag and drop" method for transfers in "My Computer".
When Auto Detect is selected, it depends on the configuration of the computer, what setup for priority has been installed.
Forcing the player into MSC mode:
1. Turn device OFF.
2. Facing the hold switch slide it to the right so an orange color would show putting the device on Hold.
3. Connect the device to the PC.
Information for the USB connection mode and how to make hidden files in XP and Vista visible, on the support site:
http://kb.sandisk.com/app/answers/detail/a_id/447
Manual for the m200 series players (readable with Adobe Reader):
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Need more help ? Don't hesitate to add a comment.
Apr 15, 2010 | SanDisk Sansa m240 MP3 Player
I hv sansa clip 1gb - in which i have some songs i.e aprox.850mb and that cannot be seen in my pc in sansa clip as a drive g.how to delete songs and add songs , is there any driver of software or...
1. First, check your device setting up on MTP or MSC? Turn on device, go to "settings" , press down or up to find "USB Mode", you can see the check mark at MTP (auto detect) or MSC mode. Change to another usb mode.
2. You have 2 ways to delete songs:
2.1. Delete songs by device: play songs, press down (sub menu) until you meet "delete song", select it and yes
If you delete all items in device: Settings, Format, and yes
2.2. Delete songs by computer: plug device to computer, double click on device icon, Music folder, and delete songs you want. If you don't see songs in there, unplug the device from pc, and then change USB mode, and plug device to pc to delete.
Good luck
Feb 01, 2010 | SanDisk Sansa Clip MP3 Player
Deleting songs
use windows medisa player and push the plus sign and then right click on the songs you dont want and it works.
Jan 19, 2008 | SanDisk Sansa e250 MP3 Player
Can't change songs
put the player in MSC mode in settings: go to MYCOMP and open the player, go to the music folder and delete the songs.
Jan 16, 2008 | SanDisk Sansa m240 MP3 Player
Sansa250r
To delete files using the MSC mode, please follow these steps:
1. Open "My Computer" and Open the "Removable Disk" that pertains to the player.
2. Open the folder where you copied the songs, if applicable, and locate the songs that you want to delete.
3. Highlight the songs, press the "Delete" key and click "OK".
Using the MSC mode, you may also delete every file that you have put in the Sansa by formatting it. To format your Sansa, please follow these steps:
1. Open "My Computer" and right click on the "Removable Drive" that pertains to your Sansa.
2. On the drop down list that appears, choose "Format".
3. On the "File System" drop down list, select "FAT" if your Sansa is less than 2GB. Otherwise, select FAT32.
4. Click "Start".
Dec 01, 2007 | SanDisk Sansa e250 MP3 Player
I can't delete the songs and the computer says my mp3 is "full"
You need to be in MSC mode to do deletion in My Computer; put in MSC mode in the settings menu under USB, then plug in, go to My Computer and open it as a drive, go to Music folder and delete by rightclicking on songs and choosing delete. You can also format the player by rightclicking on the drive letter of the sansa and choosing format. If you are deleting from a program like Rhapsody (ugh) or windows media player, you will get a lot of issues and not all will delete. Stick with My Computer in MSC. Also as a side note, make sure you have all file folders showing including hidden files in the tools menu in My Computer
Oct 19, 2007 | SanDisk Sansa m240 MP3 Player
I can't remove songs with WMP
You have to first change the USB mode on the player to MTP (as opposed to MSC). Forget using the Windows Media Player (yeah, I know). Go to Explorer, go to drive E or whatever your Sansa is listed as....open it and it will show different types of folders. Go to MUSIC folder. The songs are listed and you can delete, e.g. delete mp3 and keep WMA of the same song, or whatever else you want to delete.
Jun 24, 2007 | SanDisk Sansa e250 MP3 Player
NoSpaceForDB Please Delete MoreThan4.0MB
hmmm i'm not familiar with the problem but try this.
First open your mp3 player and go to settings. Under the USB menu change it to MSC. Then plug in the mp3 player to the computer. Open the My Computer on your desktop, right click on the Sansa mp3 player and click Format. Make sure Fat32 is checked and Quick format is UNchecked. Then format the mp3 player. After that it should be clean and work just like a USB drive.
Let me know if this helps!
Apr 07, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
177 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
