Question about Karcher 2500 PSI Pressure Washer
I have a Honda Kodiak CG2800R and after I shut it off after only 20 min of use. I can't start it back up again? Can't pull the cord. Don't have the manual and not sure where how to check the oil, can't find it. Need help.
  • firehead May 11, 2010
    Does the Honda motor have a model number on it? Like GX340
3 Suggested Answers
  • 4 Answers
SOURCE: Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
Posted on Aug 23, 2009
Testimonial: "Sounds good! I'll check it out and let you know. Thanks!"
  • 241 Answers
SOURCE: pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Posted on Mar 24, 2010
Onan generator
Hello, I would check the valve clearance. If the valve clearance is too small, the valves can expand in length as the engine comes up to running temperature and lose compression in the cylinder until the engine cools back down and the process starts all over again
Aug 15, 2014 | Electrical Supplies
Shuts off and wont start again until cold
hi often its crankshaft sensor they shut down after 15 or 20 min and restarts if u let it cool down also known as ckp sensor danny
Mar 18, 2014 | Honda Odyssey Cars & Trucks
Won't go into reverse
Sounds like you live in the northern part of the US. If so, have your mechanic install a block heater in the freeze out plug of your vehicles engine. Then plug the power cord of the block heater overnight. You should have no problems in the morning,.Check trans. fluid..........
Dec 24, 2017 | GMC Cars & Trucks
Need help starting a gx340 honda with new ring kit ,honed cylander,lapped valves,adjusted valves with new ex valve seal.started warmed up and changed throttle level from low for 10 min to med for 10 min...
If there is air in the tanks, it will be harder to crank, drain air out before starting, Also check spark plug. Sometimes i put gas where the plug goes, just a little pinch of gas though. put spark plug back and give it a few cranks.
Oct 02, 2013 | Honda Jenny GT8HGB-30P 8hp 30 Gallon GX...
1998 honda civic, starts and runs once I shut it off and try to start again it just spins and will not catch after about 15 20 min. it will start again, what might the problem be?
It sound like you have a bad relay. Its getting hot and has to cool before your car starts. Its probably the EFI main relay.For a guide on checking the relay CLICK HERE
Oct 01, 2010 | 1998 Honda Civic
2002 Honda Civic - In town driving when suddenly felt a drop in speed/rpm -emission control light comes on and the car will not goi over go over 28 mph - Pulled over and shut engine off for about 20...
Recommend you have the car scanned to pull the trouble code history. You'll want to know what the car thought was wrong to see if you can avoid same problem in the future. Many parts stores have a free scanning service (Autozone, Advance, etc.)
Sep 23, 2010 | 2002 Honda Civic
89 blazer shuts off when driving.pull over let sit for couple min
Hello it hapend to me with my car i just replace the crankshaft position sensor !!!
Apr 04, 2009 | 1989 Chevrolet S-10 Blazer
Karcher 2500 PSI Pressure Washer Logo
205 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
