Question about Datamax E-Class E-4205A Direct Thermal Printer - Monochrome - Desktop
Printer will not advance to tear after print
Does advance to tear if manual button is pressed. sensor seems to be working
    New Friend:
    Problem Solver:
  • 11 Answers
Good Day
Are you referring to the position where the label stops after printing to be on the backing (gap) between the two labels in order to tear it without pressing the feed button to do so?
Seems like the stop position after printing is incorrect.
Firstly you can do a Quick media calibration by switching the printer off, hold down the feed button while switching the printer back on, hold down for 10 seconds until the LED Light blinks Green and release. The labels should start feeding and then stops, press the feed button once to feed one label and see if it stops at the tear position.
This can also be corrected by using either the DMXConfig Configuration Utility or NETira Configuration Utility when using a USB, LPT or Serial connection to set this on the printer, look out for something like "stock" or "stop position" and choose "Tear Off".
If all else fails, try doing a Manual Media Calibration by using the Wizard in NETira Configuration Utility.
Good Luck
Posted on Nov 19, 2014
I can't give the exact solution for this printer, however, I use the Epson POS thermal printer and here was our solution. In Windows 7 go to Devices and Printers. Click on Printer Properties. Then see if you see a tab that says Document Settings. Under that setting click on Paper Source. You should now see several options; I have mine set on Document(Feed, No Cut). There are other options but we prefer to tear ours off. You can chose Document(Feed, Cut) and it should advance then cut the paper for you.
Posted on Jul 29, 2014
SOURCE:
The motion sensor on my 5 foot singing dancing Gemmy pirate skeleton isn't working. Where is the sensor located, and how do I fix it?
De-pant the skeleton and took a look down there in the foot where the inputs are. There should be a small circuit board. The proximity sensor is on a pair of green wires, yellow wires connected to the manual activation switch, connections to the various motors and the speakers up in the body, and a pair of long green wires that seem to be jumpered together. It's the proximity sensor that's likely at fault. Check to see if there is anything blocking the sensor. If nothing is blocking, check for loose or broken wires to it. Otherwise, you could remove the sensor and try to match it up at an electronics store and install a new one.
Jan 23, 2016 | Toys
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
The set is connected by USB to the laptop but I can't get it to work. Reset buttons, new batteries, checked usb plug, blown clean,nno dust, light on the receiver is on, lights flicker when the reset button...
it seems that there is connectivity problem.. as your sensor is not receiving signal from keyboard or mouse.....you have to make connectivity by pressing button on sensor then press button on keyboard....similarly press sensor button on sensor then press button on mouse.....try this and do reply me
Oct 03, 2009 | Logitech Cordless Desktop EX110
Ford backup sensors not working
I would buy a Chilton Repair Manual from a local parts store and a digital ohm meter. If the chilton doesn't have the ohms for all the sensors then research online for the specs on the sensor. It sound like a wiring issue or relay.
Mar 25, 2009 | 2005 Ford F 350 Super Duty
Setting top of form for zebra 2844
Hold down the green button, then power on. As soon as the light turns red, release the button. The printer will go into calibration mode. When complete, press the green button one more time.
Aug 26, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Paper Out Sensor Not Working
try pressing the load/eject button and switch off the printer then switch on again
Jul 25, 2008 | Epson LQ-1050 Matrix Printer
Pioneer VSX 915 powe off
Had a power surge last night and got the same problem. Unit wont power on and has a blinking blue light on standby button. I found the solution from the service manual for a similar model.
Hold down ENTER and ADVANCED SURROUND buttons.
This resets the DC overvoltage sensor and bingo the unit comes back to life again.
Jun 18, 2008 | Pioneer VSX-915 Receiver
Label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
May 14, 2008 | Zebra LP 2844 Thermal Printer
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 | Photography
Casio HD wristwatch-4-button
1. Press lower-left button to enter hand-setting mode (you will see a H-S appear in the LCD)
2. Hold the upper-left button until the LCD starts to flash
3. Press the lower-right button to advance the minute needle by 20 seconds. You can also hold for high speed advance.
4. If you need to advance the time by a long way, and don't want to hold down the lower-right button, then press both the right buttons at the same time and the time will advance automatically. Pressing any button will then cause the advance to stop.
6. Once you have set the time, press the upper-left button.
7. To return to time-keeping mode, press the lower-left button.
Bloody complicated, but easy when you get use to it. I travel quite a bit and this really pisses me off when I have to change the time, especially so when the needle can only move clockwise.
-Bala
Nov 06, 2007 | Casio WVA430A-1AV Wrist Watch
Datamax E-Class E-4205A Direct Thermal Printer - Monochrome - Desktop Logo
138 people viewed this question
Top Datamax Computers & Internet Experts
Alun Cox
Are you a Datamax Computer and Internet Expert? Answer questions, earn points and help others
