Question about Maytag Neptune MDG5500AW Gas Dryer
Worked fine until today. Not heating. Drum turns well
Neptune gas dryer has worked fine until today. About 7 years old. Not heating. Drum turns, all else seems to be working OK
Ken,
I am diagnosing a similar problem in my dryer. Mine is a MDG4000BWW but the part catalog looks almost exactly the same. If you haven't done so already, make sure your vent pipe is clear. Since the air flow carries away the combustion gasses, there are safety switches to shut off the gas if the vent is blocked. If the vent is clear, take off the front cover by unscrewing the four screws that hold the door and door stops. The front panel should tilt forward and come free. The gas control is pretty straightforward. There is an ignitor that heats up and glows yellow. On my machine it is on the left hand side of the burner and is very obvious. If the ignitor does not heat up, that is probably the problem. You can confirm that the ignitor is getting electricity with a voltmeter. If you don't have one try the other heat ranges on the dial. It is unlikely that all the control positions would go bad at once, so if none of them make the ignitor work I'd recommend replacing it. If the ignitor works then a solenoid (electric control valve) should open and allow gas to flow into the burner. If the ignitor goes off without the burner starting, then the primary solenoid needs to the replaced. If the burner lights but does not stay on, then there are two potential problems. There is a flame sensor that detects the fact that the burner is on and sends a signal to a second solenoid to keep the gas on. It may be hard to tell which is the problem without a meter. My bet would be the solenoid. If the gas comes on properly and stays on for more than a minute or so, but then goes off and does not come back on I think you have a thermostat problem. There are two (on my machine) one to prevent overheating and one that cycles that gas on and off to maintain temperature. The high limit thermostat is to prevent fire if the cycle thermostat fails. All the parts are available online and range from about $16.00 to $35.00. Hope this helps - good luck
Posted on Jul 06, 2009
Your heating element is gone, need new one
Posted on Jun 29, 2009
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
I have a maytag neptune which is about five years old. It runs fine, but the dryer does not heat up. What should I do orcheck to diagnose problem?
heatman101
Jul 11, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Unit will not dry clothes....vent is clear; no breaker problem; not over loaded; was working fine. unit is 6 years old.Will sometimes heat up at the start of the cycle but does not stay heated.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer not heating.
Commontly thermal fuse is damage need check and change if necessary.
Oct 02, 2009 | Dryers
Neptune Gas dryer burner will not continue to fire
There's a good chance you need to replace the igniter. Careful, they are brittle !!!
Sep 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore gas dryer runs but not heating
Try replacing the valve coils first, then the valve if the prior doesn't work. If there is a buzzing noise, I believe it's more likely the valve. I'm replacing both on mine to be sure.
Aug 18, 2008 | Kenmore Dryers
Maytag Gas Dryer SDG515DAWW - heating stopped
if it dont come on in 30 secs replace it
Dec 30, 2007 | Maytag MDG2706A Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
562 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
