Question about Hitachi 50UX26B/27K 50" Rear Projection Television
Hitachi 50ux26B keeps turning off.
I have a Hitachi 50ux26B made in 1996.
The picture was acceptable and the convergence was correct when it will actually stay on.
Inside all of the Green LED's come on for a few seconds to a few min but eventually the TV shuts itself off and the only LED left on is the Red one with the word Protection near it.
There are 5 green led's that I can see. 2 I can not get the numbers of because they are on the other side of the heat sink but the ones on the left of the heat sink are D951, D952 and D950.
I am not sure but I think the board number may be JK03161, however there is a large white sticker with AP63 on the board for the AV inputs and the same type of info on the board AP6X Sigma. I am comfortable using a soldering iron on the TV because if it won't work without my help it may be on a trip to the scrap heap. After selling the parts that would be useful to someone else that is. Waste not, want not.
I have downloaded the service manual however is a there a trouble shooting manual, or does anyone know which items may be at issue in this TV from past experience?
Thanks,
Gary
  • VTXRIDER1800 Jun 29, 2009
    Skyassoc,
    I would say the longest it stayed on today while testing it out was almost 10min perhaps a little less I was not counting the time but had time to complete the auto tuning for convergence and channel line up screens, and that was after being off for at least a few days. After that each time after that less than 60 seconds. I would say that the problem is progressive and that the last few attempts to check out the LED’s it only stayed on a few seconds.
    As for which ones go off first I would say that they are the two I could not read earlier on the far side of the heat sink the D953 and D954 LED’s. The LED’s to the left D950, D951, and D952 slowly fade out after the other two shut off.
    I did not think about it but yes I did have to press the power key multiple times or unplug it and plug it back in as this would turn it back on as well.
    Gary
  • Steve Yocum May 11, 2010
    How long at it's longest piont does it stay on? When you observe the Green LEDS, do you notice if any go out quicker than the others? When it shuts down, do you have to press the power button twice to power it up again or just once?
  • 668 Answers
There is a chance that the one of the power relays are causing the problem. They have been known to be intermittent and even work for 5 sec. or 5 days before failing. When the back is off, turn the set on and when it shuts down lightly tap the relay/s in the power supply lightly and see if the set comes on for any length of time. If it does, replace the relay
and you will fix the problem. Let me know what you find.
Hope this helps,
Skyassoc
Posted on Jun 30, 2009
How do i manully converge 50" Hitachi projection
You have to get into whats called DCAM mode to manually converge the set if you don't see a menu option for convergence. Goto the site www.tvrepairkits.com - they have a DCAM article on their tips page.
Aug 26, 2011 | Hitachi 50UX26B/27K 50" Rear Projection...
Starting to see double
The tv have a problems known as a convergence problems,it dead.Tv have colors R,G,B lines mis alignments,have colors shadows pictures or 3D colors pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Hitachi 50UX26B/27K 50" Rear Projection...
I have a Hitachi. It will turn on with a good
replace Both of your STK ICs they are big black ICs will have part number on them example STK392-110 Call Mats for parts 1-800-628-1118
Nov 13, 2009 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 50ux26b projection TV, the color lines separated...
It sounds like a convergence problem; either bad solder connections at one of the convergence Ic chips or a bad Ic. if this was helpful give me a vote----if one of the chips is now bad it will have to be replaced(usual thing is to replace all the convergence ic chips---most use two and a few 3.
Aug 12, 2009 | Televison & Video
Hitachi projection tv, 50ux26b, picture jumps after it has been turned on ~20 seconds, then it settles down and works fine. advice?
The two most common problems with Hitachi projectors are in the verticle sweep circuits or the convergence. Both can cause that symptom. The good news is it is likely to be bad connections on the convergence power pacs or the verticle output IC or both. If bad connections are observed it is a good idea to resolder all suspected bad connections in general. There is a remote chance that the problem is out of tolerance filters on either the main sweep board, or a problem on the PIP module circuits. Consult with a repair specialist if you need more information.
Apr 27, 2009 | Hitachi 50UX26B/27K 50" Rear Projection...
50ux26b Hitachi
Good Day;
Sounds like the Convergence Circuit in the TV has failed. Call an Authorized Service Center and have them come out and give you a wtitten estimate B4 repair.
Good Luck, big IRISH.
Sep 27, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Picture problem
Can you post a picture of your picture so I can see the type of distortion youre having? It sounds like a convergence Issue, but a picture would help me acurately diagnose the problem. Please respond to this same post.
Jul 01, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi Projection TV power problems
Good Day,
If TV wont turn on check Q912, Q913 & I901. If no click of relay Check Q003, als chech the Convergence IC's.
Jan 03, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi Projection Color TV
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Open Questions:
Televison & Video Logo
349 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
