Question about Razor E300 Scooter
How do you put air in the back tire without taking the whole back tire off? Or is that the only way?
I just did this a couple hours ago. taking off back tire will not help you. The rotor is attached to the wheel itself. You need to line up the hole in the rotor with the valve stem. You will need to have a screw on extension to valve stem ( I got lucky and had one). Screw the extension onto the valve stem then use air compressor to air up the tire.
Posted on Jul 22, 2009
You can buy metal valve extenders at any auto parts store. I bought a 4 pack of them and by screwing 2 of them together got a nice metal extender as long as the plastic one that came with the scooter. After that you just line up the hole in the rotor with the valve stem of the tire, screw in the extender and pump it up. Don't forget to take the extender out again after inflating the tire. That could be a bad thing...
Posted on May 25, 2011
  • 3 Answers
Sometimes that valve extender is stored inside the handle bars.
Cheers
Posted on Oct 07, 2014
How do I put air in the tires?
It is possible that your scooter may have solid tires which means no air is required. You should be able to see a hole in the wheel rim where, if air tires were fitted, the valve would come out. No Valve=No Air. The rims are of the split type which you have to take the bolts out in the middle of the wheel to split the wheel to change the tires.
Jun 11, 2014 | Pride Mobility Products Maxima 3 Wheel...
Just had brakes put on and back tires but the message center is still showing saying I need air in the tires and the brakes pads need service
the garage may have broke the air sensor in the tire. as the brakes Mercedes brakes have a wire sensor in them and the shop must have put on the cheap brake pads with no wire . take it back to them
Nov 07, 2012 | 2008 Mercedes-Benz Mercedes Benz E Class
Rear wheel locked shortly after changing flat tire on 2001 e320
Take the tire off again, and then put it back on, after checking to make sure the wheel will spin without the tire on it, and without the parking brakes on. Make SURE THAT YOU BLOCK THE TIRES SECURELY TO PREVENT THE CAR FROM ROLLING WHILE IT'S JACKED UP IN THE AIR.
Sep 20, 2012 | Mercedes-Benz Cars & Trucks
Dealer installed John Deere tires won't hold air
the only way to know without taking them off but most leaks on mower wheels is rust on the beads have them install tubes and be done with it because the y will never seal like new
Apr 15, 2012 | Garden
How do i take the wheel sensors off of a 2007 ford five hundred?
Hi, if you are referring to the tire pressure sensors they are actually the valve stems that you put air into the tire with, the sensor is inside the tire and it is not able to be taken out without taking the tire off of the rim and removing the sensor and installing a standard valve stem. But if you remove the sensor your little tire warning light will stay on. Good luck
Dec 09, 2010 | 2007 Ford Five Hundred Limited Sedan
My front tires look low. Tires just 1 year old but don't want to go "pay" for check. I have a gauge and can use it. BUT WHAT is the pressure for my car? Label under gas lid is gone.
For most tires the recommended pressure is around 35 psi (sae sorry I don't know metric) Without the label what i can recommend is to take the pressure of the back 2 tires, average the pressure and then put the front tires at that pressure. If they still look low add air at about 2lb increments just enough to make sure the tread is flat and square. Make sure all tires are at equal pressure. If the front tires continue to go low spray the tires gently with soapy water looking for air bubbles. It will show a leak if there is one and then you can have your tire repaired for less than the cost of a tire. Good luck.
Feb 03, 2010 | 2000 Volkswagen Beetle
How do you remove front wheel bearing
is this front wheel? rear wheel? or 4 wheel drive? if you have front wheel drive or 4 wheel drive you will need to take the tire off and get the center cap off with cotter pin on most vehicles. then put the tire back on without its center cap. then put the vehicle back on the ground. then use required socket with an extention and breaker bar to put through the rim to loosen center hub bolt about a quarter turn. just enough to break it loose. then take the tire back off to finish the job. remove the brake caliper and rotor then center nut on hub bearing. there should be 3 bolts from the inside holding hub bearing on. on rear wheel only you won't need to take the tire off and on.
Oct 08, 2009 | 2000 Honda CR-V
Vibration
It sounds like a possible bad front wheel bearing they will make like a humming or growling noise.The pull could be air pressure a little lower in the right front tire than the left front check the air in all tires and if pull is still there take the left front put it on the right front and put the right front tire on the left front.Sometimes tires get what they call radial pull and that will fix it or make it go the other way if it goes the other way either get new tires or put the back tires on the front of the vehicle and put the front tires on the back.
Feb 22, 2009 | 1992 BMW 7 Series
Chrysler Crossfire tyre dilema
They are tubeless sorry buddy but you need a new tire. You can not fix cuts on the side wall of a tire for many reasons. Beside, if you can afford a Crossfire you can afford the tire, right? ;-)
May 15, 2008 | 2001 Chrysler Crossfire
Razor E300 Scooter Logo
4,287 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
