Question about LG WM2688HWM TROMM SteamWasher
I have an lg dryer the cooling light is on and it does not heat
  • 3 Answers
Even when mine is running the cooling light is on. I had this same problem and after replacing the heating element it still did not work. I then went ahead and hooked up a different dryer to see if that one would work and still the same problem. Having it happen to two dryers made me think it was the fuse in the circuit breaker. I replaced my 30amp fuse and went ahead and got a 40amp just to be on the higher side. Now it works just as new, especially since I went ahead and bought the new heating element. The fuse was a mere $17.00 .
Posted on Aug 25, 2009
The cooling cycle was interupted some how within the processor. Remove power to dryer by breaker or unplugging for two hours and it will reset itself then repower and you are good to go.
Posted on Jul 30, 2009
My Lg Dle5977s, will not heat up, had new heating element installed and it work at the repair shop, the cooling light is staying on
Check power to both legs of you 220 v outlet.
Cooling light always stays on-not an issue.
Sep 01, 2017 | LG Dryers
My lg dryer dle3777 electric is not drying. The cooling cycle light is blinking and the air never heats up.
Check the heating element, Hi limit or any thermisters(Especially on the exhaust). The heating element should read about 40 ohms.
http://www.repairclinic.com/PartDetail/Heating-Element-Assembly/1268157
See if this helps.
Feb 22, 2011 | LG DLE3777 Electric Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
DRYER WILL NOT HEAT UP. "COOLING" LIGHT STAYS ON CONTINUOUSLY.
You dry by sensor???
Clean your sensor. The machine thinks the clothes are dry because the sensor is covered with who knows what???
Check your owner manual for the proper way to clean the sensor.
I hope this works for you
a
Sep 25, 2009 | LG DLE7177 Dryer
I just moved and my LG dryer does not heat up.
Your ignitor (glow bar) got broken during the move. They are more fragile than your grandmother's fine china
Dec 16, 2008 | LG DLG9588 Dryer
Lg dle7177 electric dryer
The cool light on the lg is on all the time. It is only actually cooling when it is flashing. You might have a blown thermostat. Call a tech and have him/her check it out.
Sgt48
May 18, 2008 | LG DLE7177 Dryer
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
Cooling light
The cooling light should be blinking. Mine did the same thing. It ended up being the fuse that was going to the dryer from the circuit breaker itself. I ended up replacing the whole heating element thinking that was the problem. Turned out to be a $17 fuse and problem solved. Hope this helps.
Oct 07, 2007 | LG DLE2514 Electric Dryer
Cooling light
The lights that come on are what the machine is going to do for the entire cycle. If you notice it will start to flash towards the end of the cycle. That is when it's actually "cooling" the clothes to try and reduce wrinkles. The dry light flashes while it's drying. As for the not heating at all you need to check for blown fuses or popped breakers.
Sep 24, 2007 | LG DLE2514 Electric Dryer
Washing Machines Logo
230 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
