Question about Sewing Machines
My Kenmore has started breaking or bending my needles, I can't find anything loose. If you could help that would be great.
  • 111 Answers
Does the hook assembly rotate as you turn the handwheel? if "no" then your lower gears are shot
Posted on Jul 08, 2009
What is the needle size for brothe 911 sewing machine
Be sure to change the needle frequently, ie every time you start a new project. Needles will cause a great deal of frustration yet are the least expensive item to fix.
Perhaps this will help:
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwia3-aY5LrQAhUHqVQKHUgcC5UQjBAIJDAB&url=http%3A%2F%2Fwww.schmetzneedles.com%2Fneedle-guide%2F&usg=AFQjCNG5DmrsyBAUhhGLeiVfmc4jHpjYsQ
Nov 21, 2016 | Sewing Machines
The needle keeps breaking
Either you have the wrong foot installed or your stitch setting is incorrect. Dial in a narrower setting. You may have a zig-zag setting without the zig-zag foot attachment, or your "width" dial is too wide for the foot's hole. Slowing turn the wheel and watch where the needle penetrates the foot hole. A collision at that point will break your needle every time!
Apr 24, 2016 | Kenmore Sewing Machines
My neddle keeps bending the side and breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Dec 03, 2012 | Singer 2732 Mechanical Sewing Machine
Kenmore 385-16231 sewing machine. we are having problems with it breaking needles while sewing, we have never oiled this machine could this cause the needle breaking problem?
some sewing machines are self oiling some are not, instruction manual should tell,, when a sewing machine breaks needles it very possible that the machine is out of time & only a sewing machine repair shop has the tools to time the machine
Jan 24, 2012 | Kenmore Drop-In Bobbin 16231 Mechanical...
Does it make a difference whether I use a 14 or 16 in my Kenmore sewing machine, basic 12 stitch. I had a 16 needle in it but after my friend cleaned it, in trying it, the needle hit the presser foot>...
Hi. You use different size needles for different fabrics and fabric weights. Size 16 needles are used for heavy fabric, like canvas, duck, or blue jeans. Size 14 needles are still on the heavy/thick fabric size. Size 10 needles are for very light-weight fabrics and size 12 needles are for medium-weight fabrics. Also, you need to pay attention to the type of fabric--if sewing on knits, you need ballpoint needles. If sewing on woven fabrics, you need sharps or universals. Universals are supposed to be for knits, too....but ballpoint needles are SO much better!
Use the right size and type of needle for your fabric, don't sew over any pins (they can bend or even break the needle), and make sure you don't pull or push the fabric while you're sewing on it. Let the feed dogs do the work of moving the fabric--you just gently guide it.
Hope this helps!
Aug 25, 2010 | Kenmore Sewing Machines
Embroidery machine needle breaking
make sure your top thread is feeding properly and not catching on the spool or twisting as it comes off the spool. When i use metalic thread, i put it in a small can beside my machine and it works great.
Jan 02, 2009 | Sewing Machines
The needles on my Janome 9102D keep breaking
I had a similar problem with my machine. What I've started doing with mine is setting the stitch length at 3 and the differential feed ratio at 1.0 then I set all 4 thread tensions at 3. I thread the machine from right to left, and then when everything seems to be working okay I take scrap material to test the tension and then set them to suit the material I'm using. Right now I'm working with a twill so my settings are 4-4-5-5. This seems to have stopped the thread slipping off the bottom looper and I haven't had any more needles break. I hope this is helpful.
Dec 02, 2008 | Janome Harmony 9102D Mechanical Sewing...
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
