Question about Haier HTN19R12S 19" TV
The word "factory" is appearing 19"HAIER T.V.
I've got the word "factory" appearing on every channel and I don't what I did to make appear and now it won't go away after I unplug for 15 minutes do you know what I did wrong?
Thanks Paul Lee
plee1382@yahoo.com
800-663-1305
    Guru:
  • 224 Answers
Try www.xdiv.com/remotes
I found the GE 3 in 1 Model #RM24912 at Walmart for about $7 that worksperfectly. The booklet lists 5 codes for Haier, and code 0217 works allthe functions on my tv, including mute, channel return, and even themenu for color adjustment, sleep timer etc.
The code that I'm using is "0748", but try the codes provided - 1034 or 0768 and see what happens.
Codes
0081
0216
0217
If your remote is a 3 digit remote just drop the zero ie. 081, 216, 217
Hope it work's,
If all the other functions work on the tv remote, then turn the tv off,then un-plug it for 10 minutes. Plug it back in and turn it on. If theinput button still doesn't work then go into the tv menu and try and change it there.
Hope this works,
Nalin :)
Posted on Jun 29, 2009
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
Jan 16, 2014 | Panasonic CT-34WX52 34" TV
Hi i forgot my unlock pattern what can i do
Try your pattern 15 times and a dialog box will appear that will link you to sign into your Gmail account where you can create a new pattern password.
If you don't remember the password for your Gmail account, you will need to complete a factory data reset. Factory reset will permanently delete all your data and customized settings, and will remove any applications you've downloaded and installed. SD and SIM card data will not be deleted.
With the phone turned off, press and hold the Volume Down button, and Power button for 10 seconds.
Wait for the screen with the 3 Android images to appear, and then release the buttons.
Press Volume Down to select FACTORY RESET, and then press the Power button.
Nov 27, 2011 | HTC Inspire 4G Smartphone
WHAT IS THE PORT UNDER THE HAIER 7 LCD THAT SAYs update HOW DO I USE THIS FEATURE WHAT IS IT USED FOR DOES THIS UPDATE THE TV ?????
This is a Star Trek GNDN USB mini port for the Haier factory to update the firmware (software stored permanently) in the TV.
If you return the set to Haier for servicing under the 90 days labor, 1 year parts warranty, Haier will probably just send you a refurbished unit.
Part of the refurbishment is for the Haier factory to update the software which runs this digital TV.
If you connect your computer to the port with the correct cable, nothing will happen.
No drivers or user mods (hacks) appear to be available.
Nov 16, 2010 | Haier HLT71 7 in. Portable TV
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
FRIEND HAS A SONY FXE 100 AND HAS LOST THE MANUAL. THE COMPOSITE VIDEO INPUTS AREN'T WORKING...BEEN HELPING HIM SEARCH FOR A SERVICE OR OWNER'S MANUAL WITH NO LUCK. ANY HELP YOU CAN OFFER? THANKS!
Chances are that the composite inputs are not selected in the settings. You need a display connected to the MONITOR output to see what you're doing. Then press the SCREEN button (just below the RECORDER readout) until "Menu" lights up next to it. Then press the large round wheel in while keeping the MENU button depressed - this will bring up the menu settings on the monitor. Then press the MENU button in the "Dial Menu" section - while keeping it pressed, rotate the large round knob until "Setup Item 101" appears in the display- this is the Video Input Select area.
Release the MENU button to select Item 101 - then press the DATA button while rotating the large round knob until S-V changes to V (going from S-Video to Composite ). When you've reached the desired setting, press the SET button to store it in memory. Keep in mind that you have to do this on P1, P2, R and/or AUX depending on which channels you want to change. The factory default is S-Video, so that is probably how the machine is set on each channel. When you've finished setting the channels to your preference, press the SCREEN button to exit the menu.
I've found that the $20 (or so) investment on one of the many manual sites pays for itself many times over in "frustration control". I can attest that www.servicemanuals.net is quite trustworthy, and in most cases you can download and print the manual immediately. The sites that offer "free manuals" are more trouble than they're worth as you have to download all kinds of crap you don't need, and they pop up when you don't want them to and slow down your computer. If you need more help, write me at barry8track@cableone.net
Jan 14, 2009 | Sony DSR-20 DVHS VCR
I have a "craig" tv and the word factory is on the upper left corner, when this word appears i can no longer use any buttons on my tv, how do i fix this?
Dec 24, 2008 | Craig CTV-41904 19" TV
Black box appears on tv screen
Check to see that you don't have any channel locks or parental parental permission measures deployed. If so remove them, this includes V-Chip, and Parental lock out on the remote, and check your TVs menu items. What channel are being affected by this problem? Give channel number and channel type.
Thank you,
Shuttle83
Aug 17, 2008 | Orion1934 19" TV
Sound no picture
If you have the 3 RCA jack cables connected to the input jacks on the TV press input on the remote until the picture appears.
Apr 13, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Haier HTF20R21 20" flat screen
In google search, type in the words "the word "factory on my tv", and it comes up with solution..it worked first time for me!.. Bill
Jan 23, 2008 | Haier HTF20R21 20" TV
Haier HTN19R12S 19" TV Logo
122 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
