Water draining on the inside
Hello my window unit is leaking on the inside it is driving me nuts i have tried spraying it out and trying to see if the drain whole is clogged there is no water in the outside of the unit its but its pouring inside
  • misszygjoyce Jun 29, 2009
    sorry i dont have a camera at this time to send a picture but it is definately lower in the back and still the water is not getting into the back of the unit it is building up in the front so i am thinking it is clogged somewhere
  • panilling9
    panilling9 May 11, 2010
    be sure your unit is tilted towards the back and not level in the window the back of the unit should be lower so the condensate from the front evaporator coil will drain towards the rear of the unit
    President:
  • 3,433 Answers
Your unit is imprperly installed. The outside end should be lower than the inside. Send a picture of the outside of the unit if you will.A side shot. co7196 @yahoo.com
Posted on Jun 29, 2009
  • Ned C Cook
    Ned C Cook Jun 29, 2009
    If it is obvious, no need to send a pic. Is there a drail hole at the other end inderneath the cabinet and throught the pan? I've come across several units with no drain hole. Noticed it when fan started splashing in the waterTook care of it with a hole saw.. If you choose to drill it, , slide the unit out of the way by slidind it into the room to avoid hitting the coils/condensor.
Frigidaire FAC107S1A leaking water thru the inside of the house
Hello, first make sure the unit is tilted back in the window about a 1/4 inch. Also, check the drain on unit, sometimes they can clog and prevent condensate from draining.
Jul 31, 2012 | Frigidaire FAC126P1 wall/window Air...
Water is draining into the house?.where is the drain?
Hello, the unit must be tilted back in the window to prevent the condensate from leaking inside. Some units will have a drain plug on the bottum, while others use the condenser fan to scoop up the condensate and splash the condenser to keep it cooler and evaporate the condensate.
May 29, 2012 | Maytag M3X05F2D Air Conditioner
My unit is frozen and leaking water. I have gone through the other similar questions and solutions. Everyone tells you why it is doing this but I can not find an answer on how to fix it. Where are the...
The problem is that you have a refrigerant leak...the leak needs to be found, then fixed, then the unit recharged...probably cost more then a new unit to do all that...
heatman101
Sep 15, 2011 | Haier hwr10xc6 Air Conditioner
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
Water leaking inward
There should be a drip tray that catches all the condensation and funnels it out the back. Check for holes, cracks or a plugged drain hole.
Aug 30, 2017 | Frigidaire FAC124 wall/Window Air...
I have a 2001 Chevy Cavalier. Whenever it rains All of my windows fog up like crazy! I have tried rain-x it did not work. The defrost/fan does not help much. My A/C does not work that well.I have to drive...
i think you have a water leak inside the vehicle ,first step is to find the drain from the heater unit ,passenger side coming through firewall is a rubber hose that hangs down ,make sure the bottom of the hose is clean
Mar 17, 2010 | 2001 Chevrolet Cavalier
106.55244400 leaking water on floor
Hello, sounds to me like you either have a leak on the nut on the water inlet valve or a pinhole leak on the inlet valve body...have come across this many times before...you may not see the leak from the valve because it is very fine spray but it's there...only real way to detect where it is coming from is to pull the valve out switch water on and see where the leak is....either this or you have a blocked drain tube in the refridge but with the info you supplied i would suggest the valve. If you have any other questions or concerns please feel free to comment again. Good Luck! Mike
Aug 17, 2009 | Refrigerators
Dishwasher leaks from bottom left corner
If its just that corner check that it is level (if not leak could be somewhere else)
Then check your hoses and valves for holes or leaks (try putting some food dye water when running to see easier
Most likely a loose hose connector or hole in the rubber hose
This hould help you
Dishwasher Basics The main parts of a dishwasher are: Control mechanism
The control mechanism is located inside the door behind the control panel. Many units use a simple electro-mechanical system: a timer determines how long each part of the cycle lasts and activates the proper function at the proper time (such as the detergent dispenser, wash spray and draining functions). Units that are more expensive might have a computerized control system. Modern units also have a door latch that must be closed for the unit to run. Some also have child safety locks. Intake valve
This is where water from the home's water supply enters the dishwasher. The unit's pump doesn't pump the water into the basin – when the intake valve opens, water pressure drives the water into the unit. Pump
An electric motor powers the pump. During the pump cycle, the pump forces water up into the spray arms. During the drain cycle, the pump directs the water into the drain hose. The motor-pump assembly is mounted beneath the basin, in the center of the dishwasher. There are two main types of pump:
  • Reversible
    These pumps switch between pumping water to the spray arms and pumping water to the drain by reversing the direction of the motor. Reversible pumps are usually vertically mounted. dishwasher-11.jpg
    -->Reversible pump
  • Direct-drive
    The motor runs in one direction, so the direction of flow is switched from spray arms to drain by a solenoid that opens and closes the appropriate valves or switches one hose connection to another. Non-reversible pumps are usually horizontally mounted. dishwasher-12.jpg
    -->Direct-drive pump
Dishwashers can be installed in either a portable or a permanent configuration. Portable units have finished sides and top that can be used as a countertop. When not in use, the machine sits in place next to the wall. When it's time to run a cycle, the unit can be rolled on casters over to the sink, where it connects to the faucet and plugs into a nearby outlet. In a permanent installation, the dishwasher goes underneath the existing countertop and bolts into place. Hoses underneath the kitchen sink connect directly to the hot water line and the drain line, and the unit usually plugs in under the sink as well. Both types of installation require a 120-volt grounded line.
Jun 07, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer leaking around drain plug
hello!
the drain plug is loosening if equiped with a housing nut try to rotatate nut to tighten the drain plug,if has no lock nut have it weld by glue gun to hold tight fit your drain plug.have a nice day
May 05, 2009 | Admiral 26 cu. ft. Side-By-Side...
Air conditioner leaking
Hi, There are no pipes, just passage ways on a window unit. It probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit through passage ways to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt or algae in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem. Since the tilt is right and it doesn't seem to be freezing, Maybe a temporary increase in tilt and a dropper of bleach at the base of the evaporator would do it. This will kill the algae and may unblock the water flow. NOTE: It may also cause stains on a carpet or floor if the bleach water drips onto it. If you want to pull it out and clean it, most units can be pulled out of the housing and sprayed with a water hose but you need to be careful not to get water in the electrical parts of the unit. They can be covered with plastic or foil. Make sure you unplug the unit before trying to remove it. You may have to remove some screws to remove it from the housing. Hope this has helped. kstfas
Sep 19, 2007 | Sharp AF-S120FX Air Conditioner
Heating & Cooling Logo
120 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
