Question about Maxtor Hard Drive
Recover Data from Internal Hard Drive
I have a Maxtor Dimondmax plus 9, 120GB internal hard drive.
it is not booting up, the hard drive is not being recognized and it keeps making a clicking sound.
Can you help me to recover the data i have on the drive.
  • Anonymous Mar 26, 2014
    How to I recapture my data on my hard drive?
Clicking is not something you fix at home by yourself. Usually it is caused by bad heads...
Check out this website for sounds your hard drive makes to find out exactly.
Posted on Oct 23, 2008
  • 24 Answers
You can use the all in one data recovery tool..Check out this link..
Posted on Nov 07, 2007
  • 317 Answers
I could if I had your drive. You need specialized software to recover data from hard drives.
  • Peter Burns Nov 07, 2007
    wow thanks for the quick not helpful. this is ridiculous.
Maxtor Hard Drive won't work
Generally speaking if the hard drive won't spin, you can't get the data.
If it will spin, you can use specialized forensic data recovery programs in linux (which is free) to recover the data.
Without it spinning, you will have to consult a hardware recovery expert, which can cost hundreds or thousands of dollars. It better be important to go this route!
Mar 23, 2013 | Computers & Internet
Need to know the capacity of A Maxtor internal drive SN:A60PVPVC Ndl:91303D6
The 13 GB Maxtor 91303D6 internal 5400 RPM hard drive can be connected via IDE. This 3.5" drive is designed for use with Windows. The 91303D6 is a drive with 512 KB of cache.
Aug 08, 2010 | Maxtor Hard Drive
Can't view content of Hard drive by windows explorer
If you cant boot to windows, it maybe worth trying to boot to a CD version of linux. This way your files can be recovered. If the hard drive is bust you wont be able to see it in the linux Operating system
Here is a link with info how to recover your data
Jul 18, 2010 | Maxtor DiamondMax Plus 9 120 GB Hard Drive
I have a Big Disk Extreme 2TB external hard drive, in fact I have 2 and one of them just started to give me some problem yesterday after one year of use... all of a sudden my computer doesn't see it...
Apparently one of the disks in the BigDisk array went bad.
If you had the unit configured as RAID 1, you may be able to get your data back by removing whichever of the two internal drives is faulty (just disconnect the internal power supply cable). The unit will boot in failure mode, but the data should be accessible.
If you had the unit configured as RAID 0... that's trouble. Most technical services (and many Linux enthusiasts) will be able to recover half of the data on the unit, the half residing on the intact internal drive. The other half, the data on the faulty internal drive, might be lost or very expensive to recover (there are services which will attempt to do that, but they're SO not cheap).
If you had an up-to-date backup, determine which of the two internal disks is faulty - unplug them one at a time and boot the unit; the faulty disk will likely boot with clicks and clatter; then unscrew it and purchase another of the same model (check the DIP switches and/or jumpers for EIDE models, and configure the new unit same way as the old). Reformat the unit and put back on it the backed-up data.
Jan 03, 2010 | Computers & Internet
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
Broken external hard drive
if the broken piece is internal and rattling around, it is most likely terminal and you need to replace the hard drive, if it is an external part or a connector you may try a computer shop to see if it can be repaired, but more than likely that will cost more than replacing the drive, but they may be able to recover any data that is on it
Good Luck
Feb 22, 2009 | Maxtor Computers & Internet
Maxtor slave settings to recover data
Leave your original drive in your PC set as master, set the T1600 to slave
Open your desktop, click my computer and click C drive, reduce the window so you can slide it to one side, click my computer again and then click G drive if that is what the slave is called. Make a new directory in C drive and give it a name, Drag your files over and drop them into the directory.
Nov 09, 2008 | Maxtor Hard Drive
Maxtor Hard Drive Logo
98 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
