Question about Acer Aspire 5100 Notebook
ASpire one Acer wont turn on.
I am not sure which category to put this in this is the first time i have this problem. The computer will not turn on i have tried the sugestions that you have to do a master reset. but it did not work. How this happened; I was using the netbook and the batery ran out it went into sleep mode then i plug it to the ac and waited a while and then came to wake up de computer but nothing happened. So i held the power botton and all the lights went off and i waited and then tried to turn it on again and it never turned back on no lights are on except the power and baterie light. and i hear the fans turn on but nothing else...
    Problem Solver:
  • 7 Answers
Pretty new system, so try on just AC power (remove battery) failing that, get in touch with Acer for repair under warranty
Posted on Jun 29, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
I have a Acer Aspire One D255 and the screen wont light up. shinning a light. to the screen i can see it is not frozen. i am able to. log in and. axcess the apps. easy fix? please help
I would like you to try two different things.
First press and hold FN then press f5.
If that didn't work try holding FN then pressing the left or right arrow(depends on the computer, not sure which one it is) to make it brighter. You may have to press it multiple times.
Apr 07, 2013 | Acer Aspire One D255-2301
My acer aspire 7520-5185 will not turn on
Take out the battery then press and hold power button for about 30 seconds, then put battery back in again and try to turn on. Might as well leave it without the battery for some time after holding the power button. If that doesn't help try removing RAM and turning it on without it.
By the way.. any beeps?
Jan 13, 2013 | Acer Aspire 7520-5185 Laptop
Cd drive in my acer aspire x1700 doesn't open
You are going to need a paper clip. Look fo a small hole next to the switch. straighten the paper clip and put it in the hole in the center. carefully push to activate the mechansium to open the door. Then you can troubleshoot the door. Turn off the computer then pull the power cord from it. Open the computer case find the power cable to the cdrom/dvdcdrw and push it in to make sure you have good connection. If it still doesn't work after this then you can get a new drive for less than $30.00 (usd)
Hope this helps,
Terry
Nov 16, 2012 | Acer Aspire Pc Minitower X1700
Hi my acer aspire 5315 will not boot up, i turn it on i get nothing but the little cursor in the top right hand corner...can anyone help please thank u in advance
That is probably because some important boot files are missing. What you can try is to take out the hard drive and move it to another acer aspire 5315 computer. To take out the hard drive, remove ALL electrical components (power cable, battery, etc.), open the computer's hard drive bay, and take it out VERY carefully. Make sure you do not cut the cables. That could damage the hard drive. Then, you remove the hard drive on the other acer aspire 5315 computer using the same instructions above. Then, you can identify the missing boot files (they will be in a hidden drive called System Reserved), copy them onto your computer's hidden System Reserved drive (if it's missing you'll have to create one manually), and put it back in the other acer aspire 5315 computer. Make sure that you put the wires where they were when you removed them, otherwise the hard drive might not work. Then, try turning on the computer again.
Nov 14, 2010 | Acer Aspire 5315 Notebook
Wireless wont work on acer aspire 6530g
Make sure the switch is on , or the hot key is pressed to turn on the wireless.
Look on the Acer website and download that driver again and try.
Oct 16, 2009 | Acer Aspire 6530-5143 Notebook PC
Acer one laptop wont turn on
Remove the battery and let it cool for 15mins then put the battery back in and try it again.
Jul 21, 2009 | Acer Aspire 5920-6727 Notebook
LAptop turning off whenever it feels like it.
ctrl+alt+del
make sure close all working procedure.
Jun 01, 2009 | Acer Aspire 5500 5570-2609 Laptop
I have a acer aspire 5100 pc notebook when i trun it on is they ant no harddrive found
Is the hard drive physically present?  If so, perhaps it has failed on you and it's time to replace the HD and restore a backup image or using whatever backup solution you had.  Of course it's possible the connectors came loose, but it's unlikely.  I notice you put a laptop problem in the Acer PC Desktop category; you fail to correctly present your question, but I'm sure you have improvements in the works.
Nov 16, 2008 | Acer Computers & Internet
Acer aspire 3500 wont hold charge or turn on
I had to buy an new ac/dc plug piece off of ebay (cost only like $3 bucks) to sodder onto the mother board of my Acer. Somehow the little plastic/metal piece you plug into your computer comes off the mother board really easy. Acer wanted me to purchase a whole new mother board (at frigging $350), which, frankly wasn't an option. So I bought the little plug gizmo, soddered it on, and I'm doing good now.
Apr 09, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
466 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
