Question about Plumbing
When water valve is shut water still is passing
    President:
  • 3,433 Answers
Faulty valve, needs replace.
Posted on Jun 29, 2009
Water not coming out
WATER INLET VALVE:
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Mar 23, 2015 | Samsung Refrigerators
Tip
Water Softener maintenance tips: By-Pass Valves
There are many types of factory By-Pass valves and 3-Valve By-Passes systems used on residential water treatment equipment. Over the course of years if these valves have not been used they become very hard to turn and may require the use of a wrench to turn them. This can create a big problem if an emergency occurs with the water treatment system and the water needs to be turned off. Using a wrench on any bypass valve has the potential to break it and then it won't work or worse, you have a flood on your hands as water comes gushing out of the valve!<br />What is the solution? The easiest solution is to turn the by-pass valve on and off several time every time you add salt to the system. By doing this it loosens any debris, keeps the o-rings lubricated an the valve moving freely. <br />Many systems incorporate by-pass valves with handles that simply turn 90 degrees for on and off. While manufacturers like GE, Sears, Ecowater, Culligan, Northstar, Hague among others incorporate a simple push pull valve to by-pass the system. Other companies by-pass systems may be "hardplumbed" with a 3-Valve by-pass that incorporates an inlet, outlet and center (By-Pass) valve to divert hard water past the treatment system when needed. <br />Which ever type is used with your system it is best to turn or push these valves ON and OFF several times every time salt is added (generally quarterly) to assure proper operation of the by-pass system to prevent any problems when it is crucial for them to work properly.<br />Practice these tips and your water treatment system will give you many years of quality water with fewer service issues.<br />Good Luck and Good Water,<br />RJ<br /><br />
on May 22, 2011 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Only making two to three cubes at a time!!
i WOULD TEST THE WATER VALVE AND THE COILS FOR OHMS AND FOR FULL VOLTAGE
WATER INLET VALVE:
Feb 26, 2015 | Refrigerators
Water not going into well water tank
Is the pump running when power is ON?
Put ear against pipe and listen for pump.
Have you installed a check valve?
Check vlave lets water pass through the pipe and enter tank, but the valve closes after pump shuts off and keeps water from falling back down into well.
Aug 23, 2014 | Amtrol WX-302 WX-302 150S1, 86 Gal...
Not enough water coming into dishwasher. How do you know if it is the water valve or float? Water valve passes continuity test
If not enough. take apart the source hose and the inlet valve and look for restrictions..Machines now days use less water and the inlet of water is timed and not controlled by the float switch, soooo restricted water means you have less water.
I would disconnect the hose at the inlet valve, put it in a bucket and test it's flow. Sometimes the rubber washer deteriorates in the shut off valve, under the sink, for the dishwasher.... But both the hose and the inlet valve to the machine can have screens that plug up...
Doc
Apr 03, 2011 | GE Dishwashers
My pressure relief valve on my boiler is allowing water to pass through constantly.how do i adjust it to stop the water flow? only have about 15 pounds of pressure in system
Even a small amount of crud on the rubber washer/sealer can cause the valve to seep. Some valves can be taken apart and cleaned but it will be better to replace the valve. They can be found on line for around $12 or more. You will have to shut off the water in take valve and drain most of the system unless you have a main line shut off valve so the system wont drain back into the boiler. These valves are usually set at 30PSI.
Feb 21, 2011 | Watts Regulator Temperature and Pressure...
After turning on water heater it stays on for about 10 minutes then shuts off. There is warm water for about 25 - 60 seconds then goes cold. It does restart. Any ideas? Changed propane regulator after...
I'd check position of by-pass valve(s) on back of water heater. Sounds like they may be in wrong position. Remember, you want cold line going ( in) to bottom of water heater to be open, as well as hot (out) at top connection open. Any valves in between should be closed. Depending on what type of by-pass set-up you have, as some are 1,2,or 3 valves. Let me know what you find.
Dec 04, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
My Kenmore washer will not shut off the hot water at the end of the fill cycle
Water valves work on a hydraulic principle, the surface area of the valve where the water comes to the valve is more than the opening that it passes into the machine.. The pressure of the water shuts off the valve. The electric solenoid opens the valve when power is applied to fill the machine.
If you unplug the washing machine while it is filling and it keeps filling you have a bad water valve.
If you unplug the machine while filling and it stops filling you have a electrical problem or a bad pressure switch.
Jan 09, 2010 | Kenmore Washing Machines
Hot water tank shuts down after5 minutes pilot still on water
Carefully catch some water in a container from pressure relief valve (pull lever slightly) at top of tank, and see if it's up to temperature. If it's hot there, I suspect your by-pass at back of the tank, is faulty. Depending on what by-pass system your using, it may be in wrong position, blocked, or mixing hot and cold. Cold water flows into bottom of tank, and hot out the top. If any valve in between the 2 lines, close it, and make sure valves in and out of bottom and top are open. Let me know what you find, or if water from pressure relief valve is not hot either.
Jul 12, 2009 | RTO Atwood Water Heater - 6 Gal LP
Water heater turns on and then after a few minutes shuts down
Are you sure there's water in it? May be on by-pass. Try opening pressure relief valve at top of tank slightly,and see if water comes out. If not, check your by-pass at back of tank for wrong position. Cold has to go in the bottom, and hot out the top. No valve open, or flow between them.
Jun 25, 2009 | RTO Atwood Water Heater - 6 Gal LP
Plumbing Logo
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
