SOURCE: bose companion speaker stopped working!?
What happened to you is probably mere coincidence with your cousin's use of the headphones and this is throwing you off. I own the Bose Companions also and they stopped working as well. However, I traced the problem to the "wall wart" power supply. Not sure why but Bose is now using an interchangable plug on them. If you look at the power supply you will see a "PUSH" button. If you depress it the plug can slide out. When it is slid back in and locked in place the connection between the plug plate and the power supply is not a good one. Try fiddling with it. But even if the connection is not the culprit, something in the power supply is. I swapped another power supply with the same connector and spec's ( amps must be the same ) from another item and the speakers worked perfectly.
SOURCE: Bose Companion II Computer Speaker: The AC power adapter burnt
My puppy chewed through the cord for my a/c adapter, I just took the speakers into Circuit City, and they found me a workable replacement (the replacement isn't BOSE, but it works just fine). Hope that helps!
SOURCE: Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
SOURCE: Loud hum when Bose Companion 3 Series II speakers are turned on.
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
SOURCE: Bose Companion 3 series II speakers aren't producing sound (imac)
from what I've read, the imac has a 3.5mm (.138) jack while the Bose jack is 1/8 (.125). very small difference in size (.013), but enough to cause problems.
