Question about Motorola Mobility HS850 Consumer Headset
Motorola bt hs820 will not connect to my samsung a777, it just keeps searching for it. I asked before I purchased this phone if it would work and I was told twice by 2 different people it would work.
Hold the phone button on the headset until the light comes on and the head set beeps. When this happens start the discovery process on your cell phone. When the device is discovered it will ask you for the pass code to pair the headset. I can't remember if it is 99999 or 00000 check with motorola or the paperwork that came with the headset.
Posted on Jun 30, 2009
Unlock my phone
hi codes are the best method to unlock your samsung sgh-a777 mobile from network .to purchase codes visit classicunlocking.com here they ask you the network name to which your mobile is locked then the imei number of your mobile .finally they send you codes to unlock your mobile.
Mar 19, 2012 | Samsung SGH-a777 Cell Phone
How to unlock sgh a777
You can Unlock the Phone from Network Lock using the Unlock code ,you can get the Unlock code from here Wickedunlock.com
and Follow the instructions below and Unlock it step by step:
Samsung SGH-A777 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung SGH-A777 mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-A777 mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung SGH-A777 with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-A777 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-A777 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-A777.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A777 is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A777.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-A777.
Oct 04, 2011 | Samsung SGH-a777 Cell Phone
HOW CAN I UNLOCK SAMSUNG SGH-A777
To Unlock the samsung SGH A777 model Phone use the Unlock code ..get the Unlock code from here Onlinegsmunlock
and Unlock it from Network Lock...
Samsung SGH-A777 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Samsung SGH-A777 mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-A777 mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
Method 2:
Jul 25, 2011 | Samsung Cell Phones
After charging my HS820, the light stays on, no matter what I do, and it is supposed to be in sync mode, but it won't sync with my Samsung, but my other Motorola headsets do!
You need to disconnect it from the charger and keep the button pressed to put it in pairing mode, then associate with the phone with the PIN 0000.
Jan 29, 2010 | Motorola Mobility HS820 Consumer Headset
How to connect a Motorola HS820 headset with a Sony Ericsson C510
the interface between motorola and sony ericson works only in some models..try some other headsets (of your friend's ). of the same company.if it works then its not possible to connect the device
May 27, 2009 | Cell Phones
HS820 won't activate 'voice dial' on Blackberry Pearl
Did you find a resolution.  This is the same problem I am having with the Curve.
May 22, 2008 | Motorola Mobility HS820 Consumer Headset
My Phone Does Not Locate My HS820 Headset
Try the following:
1) Make sure the HS820 is fully charged up.
2) Remove the battery and SIM card from your phone for about 1 minute and put them back in.
3) As soon as your phone is booted up, access the "find devices" function for adding your HS820.
4) Hold the HS820 button down until the blue light is solid.
5) Then do whatever your phone requres to "search for devices."
6) Here's the key: as the phone is searching for devices, PHYSICALLY TOUCH touch the HS820 to the phone.
I couldn't get my HS820 to synch with my new Blackberry Curve the normal way and ultimately got it to synch by going through this process.
Sep 11, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola HS820
the always on light mens that it is in pairing mode and wont go out until it has paired with a phone, if you wish to turn it off, press and hold for 3 seconds, it will then flash 3 times and then go off. Try pairing again by pressing and holding the button until the light stays on.
Jul 10, 2007 | Motorola Mobility HS820 Consumer Headset
Samsung e900 pairing
if you press the power button and hold until the blue light stays on the set is then in find mode, at this point use your phone to search for new devices and when it finds it it will see the HS820 and probably ask for a pin number this is 0000, when they are paired the blue light will flash and then flash intermitently from then on.
May 26, 2007 | Motorola Mobility HS820 Consumer Headset
Motorol HS820 Speaker issue
User "Nitol" seems to be having the same problem with this headset. I'd recommend calling motorola support, see what they think of it. If you're lucky, they'll recognise the apparently common probem and help you out.
Apr 06, 2007 | Motorola Mobility HS820 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
161 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
