Question about Cycling
I have an stationary bike, the left pedal keep getting loose i tighten it but it get loose anyway
    Scholar:
  • 84 Answers
Check to see if the threads (spiral edges) on the pedal stud or the crank arm is worn down. If they are, then you will need to replace one or both.
Hope this helps.
Posted on Jun 29, 2009
How do I stop the squeaking noise when pedaling the bike or using the elliptical option? I've tried lubrication. Only getting worse.
Have you lubricated all moving parts. Wheel bearings Chain and sprockets? Are there fenders if so are they a little loose?. Anything that is loose will vibrate and make a noise. Even dry pedals will make a noise. Crank also.Just a thought.
Dec 23, 2016 | Exercise & Fitness
Recumbant bike makes aclunking sound whe pedaled
follow this steps and fix it. God bless you
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess grease
Loose Pedals
Kneel next to the left side of the elliptical's base. Use the Phillips screwdriver to tighten the two screws located in the center of the left pedal.
Use the Allen wrench to remove the bolt securing the left pedal arm to the pedal leg and body arm. Use the Phillips screwdriver to remove the screw securing the rear end of the pedal leg to the crank arm.
Pull the end of the pedal leg free of the crank arm. Wipe the crank arm clean, then apply a fresh coating of machine grease or silicone lubricant. Replace the end of the pedal leg back onto the crank arm and use the previously removed screw to secure it back into place.
Join the front end of the left pedal arm to the ends of the pedal leg and body arm. Use the previously removed bolt to connect the pieces together.
5
Move to the right side of the elliptical and repeat the above steps on the right pedal arm
Dec 09, 2013 | Exercise & Fitness
My new moongoose mischief keeps getting loose chain and pedals, ive tightend it up sevral times but keeps doing it, and the pedals keep loosening from the body??? anyone know how to solve this/
My first thought about the chain continuuin to become loose, is that you need to loosen the nuts on the back wheel, and pull the wheel (while the chain is still attached to bot hsprockets) in order to remove any slack. If it's a continuous issue, chances are that back tire keeps migrating forward because those nuts aren't tight enough.
To the pedal issue-If the pedals are wobbling or vibrating because the aren't snug while on the pedal bar (the bar that the pedals revolve around) it is probably because the peddals are too large. Try buying a new set of pedals. If they are loose and trying to slip off of the pedal bar and if you have tightened the nuts that keep the pedal on the pedal bar and they are continuing to become loose, it could be that you need to use locking nuts.
A quick fix to solving loose pedals is to add washers to the end of the bar until the washers are flush up against the pedal and the nut.
Happy pedaling!
Mar 23, 2011 | Mongoose Mischief Mag BMX Bike
My left pedal is broken because it's really worn inside the pedal and I need to replace my pedals.
There are two thread sizes for pedals, make sure you get the right ones. Take the old one with you to the store.
You'll need a crank/pedal wrench to take the pedal off. The gap is too smal to get a normal size wrench in there, but you might get lucky.
Use some penetrating fluid on the thread and leave it overnight before you do it, as they are notorious for getting stuck on. Have a friend stand on the other pedal to keep it still, and undo it.
Tighten up the new one, remember the threads are backwards to normal tightening. Happy riding - vote for me please :)
Jul 02, 2010 | Wellgo 12 Crank Silver Bicycle Bike Pedals...
Right-hand pedal loose
I've had that happen with the exercise bikes that I have repaired My best suggestion is their any play after tightening the pedal if not remove the pedal an apply some blue loctite on the threads let it set up then put the pedal back. This should take care of it now if you want to get more radical then apply the red loctite, the only way to break the pedal loose is actually using a torch!!! good luck
May 22, 2010 | Jeep Cherokee Sport Disc-Brake Mountain...
Bought a Huffy 26inch magellan 700c mens commuter Bike from Kmart there was no manual having trouble figuring out how to get it into various gears, is there a manual I can down load.
just move the gear levers, but keep pedalling forward while you do. you cannot change gears while the bike is stationary and do not pedal backwards while changing
Apr 06, 2010 | Huffy Newport 26 Men s Comfort Bicycle
I wanna kno how to take a peddle of a stationary bike to fix insde
Bicycle pedals are threaded on to the crank. The right pedal has right handed (normal) threads. The left pedal has left handed threads. If you are trying to take off the left pedal, turn the wrench to the right as if you were tightening a "normal" bolt.
Oct 22, 2009 | Cycling
Cycling Logo
76 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
