SOURCE: Emporio Armani AR0532 Sports Watch with rubber/plastic strap
Here is a link to Emporio Armani Watches (paste it into your browser):
store.emporioarmaniwatches.com/products/H45820.jsp - Cached
Click on your model, then click on Customer Care tab. Here you can send an email or even contact online or by phone and get your strap sorted.
Don't forget to rate, please.
SOURCE: Emporio Armani AR0534, How do you reset the
If it is not working you may need to "AC" the watch. This generally needs to be done when the battery is replaced. This will reset the circuit board and allow the watch to work correctly. There maybe instructions on the inside of the back lid to do this but i always recommend having a watch maker/technician doing it because of the delicate nature of the circuit board.
If the sweep arm is not resetting to the 0 position then you can set by....
pull the crown out to the first or second set position then press and hold down the start button until the sweep arm is in the position you want.
SOURCE: emporio armani AR0203 face glass broken need to replace
If you have no joy anywhere else, you could try the Aramani service center. Below is an extract from their web site.
"If you have questions about Warranty or Repair please contact us at:
800-277-4013 Available M-F between 8:00am –
6:00pm CST
[email protected]"
SOURCE: I bought a ARMANI CHRONO WATCH - AR0294
Big hand is for chronometer function, not for counting seconds. The small seconds hand is for continuous seconds counting and should tick all the time.
SOURCE: emporio armani 4211
mcdevito75 here, There are 2 ways to wind your Armani Emporio watch, I'm figureing it"s an automatic watch, on some automatics you can start an initial ticking by winding the stem in any direction, if when you wind the stem you feel any resistance then this is the type of automatic watch you Start with about 20--30 winds of the watch. If on the other hand when winding the stem feels very loose and free, no resistance at all, then this is the type of automatic that relize on pure wrist and arm motion to start ticking, simply hold the watch in your hand and make small circle motions, or rocking motion, you should detect something moveing inside the watch, this is the winding counter balncer it's normal, rock or circle the watch for approx. 30 seconds to get it started. In both cases, after the watch starts, the motion of your wrist / arm keeps it wound as you wear it.
