Question about Homelite Mighty Lite Lawn Trimmer
Homelite Might lite will start but not run
I have the exact same problem and feel the exact same way. I have wasted so much time on this trimmer. I have three expand-it attachments and would like to get it to work before I pitch it and buy a Ryobi (also uses expand-it attachments).
I too have a Homelite MightyLite 26cc Model String Trimmer that will start sometimes but not stay running long enough to do work. Most times, I can't get it started. I have spent 50 dollars plus on this unit and countless hours working on it; something that should have started and ran for several years without problems. Other brands do! If it is still in warranty, I recommended taking it back to store and purchasing something else besides a Homelite and/or writing HomeLite and get a replacement model that works. This is a POS that should never been released to the consumer. Or if unit is past warranty, dump the gas, remove the plug and wrap unit around light pole before trashing. Never buy a Homelite product again. But for God's sake, just don't sell and/or give away this unit to anyone else.
KJ
Posted on Jul 04, 2009
  • 1,040 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 06, 2009
    Did this solution solve the problem?
    Jim
  • Jim Parker
    Jim Parker Nov 26, 2009
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Hard to start my homelite mighty lite, any clues please
Remove the air filter. Get some carburetor/choke aerosol spray at the auto parts store. Open the throttle wide open on the machine while spraying cleaner into the carb throat. A couple short bursts is all you need. Then try to start . If the engine runs till the cleaner burn off, that is a start. Do this a few more times and then try to start the machine normally. If it doesn't start, then it probably needs some type of fuel system maintenance done (filter, gas lines, carb gaskets and diaphragms, carb cleaning etc.).
Jan 18, 2011 | Homelite Mighty Lite Lawn Trimmer
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Can not get it started.
have you tried to replace the H T lead?
Jul 22, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite trimmer dies every time I squeeze the handle
remove the muffler,disassemble it,you will find a spark arrester screen in it.it is either clogged up with carbon or partially clogged,clean all carbon off,reassemble and try again
May 28, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite string trimmer mighty lite
does it have spark? did you replace the plug?
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
670 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
