Question about Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum
Steamvac is not sucking water up - Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum
  • 75 Answers
Probably is clogged up somwhere
Posted on Jun 29, 2009
It will not pick up the water. Help !!!!!
Problem #1 - My Steamvac is not Sucking!
If your Hoover Steamvac was working properly and suddenly it is not sucking any water, nine times out of ten, the culprit is the lid on the lower recovery tank. The lid on the lower tank (or dirty water tank) needs to hinge at the front and snap down at the back in order to creat a proper seal. If the lid snaps on but is not locked on at the front, you will not get any suction. Simply take the lid off, and ensure that when you put it back on, it must hinge on the front tabs of the tank.
Problem #2 - My Steamvac is still not Sucking!
Right now you are thinking that you shouldn't have let your brother borrow your Steamvac. And you are right, because he used the hose attachment and returned it with the hose still attached to the front of the tank (some models only). Now when you try to use it there isn't any suction. In this case, you are missing your tank duct. On models where the stair/upholstery hose attaches to the front of the recovery tank, one must remove a square plastic piece in order to attach the hose. This square plastic tank duct must be replaced before the Steamvac will operate properly in the upright position. hope this helps ive copied it
Oct 09, 2016 | Vacuums
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Al Terrain Spin Scrub motor running in reverse
if it dosent **** up the water send it back but some hoover steamvacs blow air to dry the carpet or floor faster
Aug 01, 2009 | Hoover F7431-900 SteamVac Vacuum
HOW DO i GET THE WATER OUT OF THE CARPET ONCE IT'S CLEANED?
Do you have a shop vac . Take the bag out of the shop vac ,and **** up the water . When you are done open your windows and do not walk on the carpet for at least one hour . You want your carpets to dry with the pile standing up. Carpet rake is the best thing to use . Best of luck Ed.
Jun 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Steamvac won't **** the water into the recovery tank.
This usually means one of a few things:
1. The lower tank is full
2. You did not dispense water (sloution tank empty), when applying solution to the floor.
Jan 19, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover widepath steamvac
One cause is the filter in the dirty water tank lid is pushed up too high, it needs to have a gap of 1/4 in or so. So check it, if it is up all the way, pull it down some.
Jan 15, 2008 | Hoover SteamVac F5914-900 SpinScrub...
SteamVac Supreme Vacuum Problem:
Does this have the slot in front of the dirty water tank for the hose? If it does and the hose isn't installed, there is a block that you put in when the hose isn't being used. If not there, then it will blow air and won't suck up.
Nov 11, 2007 | Hoover F5832-910 SteamVac Supreme Vacuum
Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum Logo
197 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
