Rebuilding Sharp fusers
I have been having problems when I am rebuilding Sharp fusers. When I rebuild one I am getting unburned toner on the paper. If I do 10 copies on 7 or 8 burn the image correctly. Am I putting something on wrong? Should I be replacing the thermistor, lamp and rollers all of the time? Thanks!
  • Soohound Dec 14, 2007
    It is for the 1000 models
  • 62 Answers
What model number or parts number please.
Posted on Dec 13, 2007
I have a 95 honda accord lx 4cyl automatic transmission that i am rebuilding are all the steels and clutches te same size in thickness and size?
You will know when you get it apart & measure them
You will know when you buy one of several different
rebuild kits, of your choice
Get an ATRA Paper Book Manual, to use for the spec &
rebuild
Oct 01, 2014 | 1995 Honda Accord
Sharp mx 2700n tc2 belt day
The second transfer belt is the rubber belt assembly which is inside the right door. The maintenance alert "TK2" indicates that the belt has gone past its' useful life and needs replacement or rebuilding, there is a rebuild kit available.
May 28, 2014 | Sharp MX-2700N Color Copier
Pod1_fus jam code
Jam codes should be POD1_NR (paper didn't reach) or POD1_S. (paper on the sensor flag). There's either a buildup of toner on the sensor flag just out of your fuser, a buildup of toner on the guide in the right door, or your fuser needs a rebuild. Or your 'pawls' (pick fingers) on your fuser are stuck, broken, or crooked.
Nov 12, 2013 | Sharp MX-2300N Color Copier
I have a Xerox, Workcentre 580 and I am getting a fuser error
On this model, the heat roll has a temperature sensor. If the heat roll is worn and coated with toner, this will damage the sensor. Most common problem is this sensor goes out when a heat roll is badly worn. Circuit boards on this model are pretty reliable.
This sounds like a fuser rebuild.
Feb 16, 2011 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Can you tell me what code FK1 means?
Your fuser has gone past 200,000 sheets of usage and it's time for a rebuild. You could reset the counter with sim code 24 but eventually it will clog up with waste toner and your rollers will tear up. Sharp has rebuild kits for your or you could just buy a new one.
Jan 07, 2011 | Sharp MX-3501N All-In-One Printer
Device is hanged in rebuilding
Turn it off completely. Press the reset button using a paper-clip. Then afterwards, flash again the firmware.
Sep 29, 2010 | Creative Labs Zen Digital Media Player
H5-01 Error, I need to clear this. How do I enter tech mode, I know the sequence is P# - * - C - * - 14 - start - execute. Its a sharp AR C 260
Did you open the left door and clean all the paper out of your fuser and exit area? If you cleared paper and code and get it again either your fuser needs a rebuild or your transfer belt if not moving paper through fast enough. H5-01 means five consecutive attemps to send paper through the fuser have failed.
Aug 03, 2010 | Sharp AR-C260M All-In-One Printer
Paper jam in the fuser. do you have a rebuild kit?
I couldn't find anything for rebuilding a Konica fuser, but here's an eBay listing for new ones under $100 plus shipping. This is probably the way to go since it will make your repair easier.
Good luck and thanks for using Fixya!
Feb 25, 2010 | Konica Minolta magicolor 2430 DL Laser...
Panasonic FP-7750 Black Copier
Sounds like fuser issue ( The Fuser Heats the Toner and Fuses the toner to the paper) It could also need a developer change depening on the amout of copies you have on the machine. Unless you can rebuild the fuser or replace the developer, you will have to call a service tech. If your in Maryland you can contact Innovative Copy Products if not go to panasonic.com to find a local dealer
Oct 02, 2008 | Panasonic FP-7750 Black and White Copier
Gears?
sound like the fuser to me, remove cart and turn on, does it still make the noise? if so, it is the fuser if not there is a gear drive assy, check the gears
Nov 23, 2007 | HP LaserJet 4p Printer
41 people viewed this question
k24674
jasbo
jasbo
