Question about Kenmore Elite Oasis 27052 Top Load Washer
My kenmore washing machine is making a humming sound and smells like something is wrong not a burning smell but some what of a smell and it won't work or spin the cloth.
  • 15,935 Answers
It appears your drive belt/coupling has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
My washing machjne won't do anything it filled up started to wash then stopped. Smells like something burning.
sounds like something may have shorted the motor or motor just burned windings , how old is it? did u hear any humming?
Dec 20, 2014 | Washing Machines
Burning smell while washer fills
Sound like something else isn't turning because it's jammed
the the motor is trying to turn.
May also be the starting capacitor.
Oct 16, 2013 | Maytag Washing Machines
Kenmore washing machine ultra fabric care model #92282800. Stop woking suddenly and smell like burned.
Thanks for choosing FixYa and welcome. You need to check the control panel. There is a good chance you can visually see some damage since you smelled the burnt smell. Check your belt(s) as well. Check to make sure the motor is running. Something inside may have burned up. If you have no power, check these below.
May 12, 2011 | Washing Machines
Washer filled w water but wont agitate,spin or drain. I hear a humming,buzzing and something smells like it is burning. After several attempts to start in various different cyles it may have tripped...
send the model number.if it's humming it sounds like the motor is bad.where.if it resets after a while and hums again it's the motor.there's an overload in the motor,when it gets to hot it pops and will reset after it cools.
Apr 13, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
Humming sound and buring electrical smell
yes yes yes .you are absolutely right.its the coils in the motor burning.the motor needs replacement. Often the start relay for the motor sticks and makes the motor get too hot. This can cause the motor to over-heat and shut off on the built in safety sensor inside the motor. You may need to use a amp probe to test the motor properly, check model plate for proper amps.  If this is let go too long the motor windings can also be damaged ( they may look black instead of a nice copper color). The wires on the relay are also bad for burning off the wire terminals.   The wires at the motor should be checked to make sure they have not burned off or you can test the motor continuity with an ohm meter. See two newmotor wiring pictures.....here...and...here. The relay wires often burn off as well.
May 12, 2009 | Kenmore Washing Machines
Intermittent agitation and spin, mostly just hums, burning smell after replacing drive coupling
sound as if the motor or someting else is sticking release the belt on the motor. check belt for damage. check motor by turning it by hand to see if it is free.
May 12, 2009 | Washing Machines
Kenmore Elite Oasis 27052 Top Load Washer Logo
191 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
