Question about Microsoft Select Application Center License and Sofware Assura (D93-00164-2) for PC
Program to classify input numbers. The input consist of sequence of lines. For each line, output "integral", "floating point", or "invalid" depending on whether the line contains an integer, a number with a decimal point of neither of this.
    Problem Solver:
  • 7 Answers
My email is verosaka@gmail.com please send your email address and i will send you a tiny program to do it
Posted on Jun 29, 2009
2003 buick fuse
Table 1: 4-Wire Ignition Switch Table
The body control system consists of the following 3 modules:
• The dash integration module (DIM)
• The instrument panel integration module (IPM)
• The rear integration module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each of the modules are connected to the Class 2 serial data line; many control signals are implemented by Class 2 messages.
Dash Integration Module (DIM)
The DIM is wired to the class 2 serial data line. The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Control of headlights and exterior lamps
• Horn relay control
• Interior lamps incandescent dimming
• Lamps On signal with wiper/washer
• Power moding control over Class 2 serial data line
• Steering wheel controls
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules
Apr 21, 2018 | Buick Cars & Trucks
Direct location of BCM 2005 Buick lesabre
Which one ? Your vehicle has three !
And if replaced it needs to be programmed ,dealer
Sep 17, 2017 | Buick Cars & Trucks
What does bmc mean and what is it for on 1 2001 buick lesabre
BCM - body control module a computer that controls functions on your vehicle . A BCM controls light's , power door lock's , anti-theft system control , Remote keyless entry , headlamps . On your vehicle three modules make up the body control system .
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the DIM. The PMM receives 4 signals from the ignition switch.
To determine the correct power mode the PMM uses the following circuits:
• Accessory voltage
• Ignition 1 voltage
• Ignition 3 voltage
• Off/Run/Crank voltage
Rear Integration Module (RIM)
The RIM is wired to the class 2 serial data line. The various RIM input and output circuits are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• The ajar switch and tamper switch inputs from the rear compartment lid
• The automatic level control
• The cigar lighter relay control
• The fuel door lock and release control
• The heated seat controls
• The park brake relay control
• The rear compartment lid release controls
• The rear defogger relay control
• The retained accessory power (RAP) relay control
• The reverse lamp relay control
• The various controls for the interior lamps
Mar 21, 2017 | Buick LeSabre Cars & Trucks
2000 cadilac seville occasionally doesnt respond when ignition key is inserted, no memory position adjustments, no starter when key turned. is it key or ignition switch. everything usually works fine
Is the security light lit on the instrument when it doesn't start ? The ignition switch on your vehicle doesn't work like you would probably think it does . The ignition switch is input signal to the body control system .
Body Control System Description
The body control system consists of three modules and their associated electrical controls. These modules are as follows:
• The dash integration module (DIM), located on the right hand side of the instrument panel, near the blower motor.
• The instrument panel integration module (IPM), located in the center of the instrument panel, above the radio.
• The rear integration module (RIM), located on the right hand rear of the passenger compartment, behind the rear seat.
Each module integrates input and output controls for two or more functional areas. The inputs and outputs are wired to the closest module to minimize the lenth and amount of the wiring used. All three modules communicate on the Class 2 serial data line, allowing data to be shared among them, as well as with other Class 2 modules on the vehicle as needed.
Each of the three body control modules integrate a number of functional systems under the control of a single module. Each of the modules are connected to the Class 2 serial data line.
The dash intergration module (DIM) functions include the following:
• Power moding control (ignition switch states) over Class 2 serial data line
• Control of exterior lamps
• Interior lamps and incandescent dimming
• Horn relay control for theft activation
• Low side temperature for HVAC compressor
• Hood ajar switch input (export)
• Storage of the clock settings and, sending a message on the class 2 serial data line in response to requests from other modules.
Instrument Panel Integration Module (IPM)
The instrument panel integration module (IPM) functions include the following:
• Front HVAC air delivery and temperature controls
• Ambient light sensor input and twilight delay input for headlights control
• Foglight switch inputs
• I/P dimmer switch input
• Traction control switch input
• Interior lamps switch input
• Key in ignition switch input from the ignition switch
• Fuel door and rear compartment lid release switch input
• Ignition switch headlight control
The rear integration module (RIM) functions include the following:
• Fuel level sensor input
• Heated seat controls
• HVAC blower control
• Rear defogger control
• Park brake relay controls
• Various controls for the interior lamps
• Reverse control for the backup lamps and automatic day/night mirror
• Rear foglights control
• Fuel door and rear compartment lid release controls
• Retained accessory power (RAP) control for the sunroof control module
• Ajar switch and tamper switch inputs from the rear compartment lid
• Content theft alarm
At the dealer we would hook up a scan tool and look at the ignition switch inputs to the DIM to see if has correct inputs . Also we would check DTC'S diagnostic trouble codes .
DTC B1805 Ignition Switch Problem
Normal vehicle Class 2 communication does not begin until the system power mode has been identified. The dash integration module (DIM) monitors four discrete wires from the ignition switch contacts in order to determine the present power mode (ignition switch position). The DIM communicates the system power mode to all Class 2 modules on the Class 2 serial data line.
http://www.public.asu.edu/~pheanis/documents/VBI_CLASS2.pd
Jan 12, 2017 | 2000 Cadillac Seville
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
2000 cadillac deville gas gauge avg went blank car won't start
Your best bet is have it checked for DTC'S - diagnostic trouble code's first before doing anything ! Sorry but you have no idea of the complexity of this vehicle .
Body Control System Circuit Description
The body control system consists of three modules, the Dash Integration Module (DIM), the Instrument Panel Integration Module (IPM), and the Rear Integration Module (RIM).
Battery Positive Voltage (B+) is provided from IGN SW fuse 20 in the Rear fuse Block on CKT 540 (ORN) to the DIM at connector C3 terminal G. The module ground is on connector C3 terminal E, which is wired to ground G201 by CKT 451 (BLK/WHT). Battery positive sense voltage is provided from DIM fuse 39 in the Rear fuse Block to the DIM at connector C3 terminal A12 on CKT 3340 (ORN). This battery input is referenced to the ground sense input at DIM connector C3 terminal B12, which is wired to the battery negative terminal and to ground G307 on CKT 50 (BLK). These sense inputs are physically connected to the battery positive and negative terminals for accurate battery voltage readings. The DIM is wired to the Class 2 serial data line CKT 1807 (PPL) at connector C2 terminals A11 and A12. The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
Instrument Panel Module (IPM)
Battery Positive Voltage (B+) is provided from I/P fuse 7 in the Underhood fuse Block on CKT 440 (ORN) to the IPM at connector C1 terminal C1. Ignition Positive Voltage (IGN3) is provided from the IGN3 RR fuse 6 in the Rear fuse Block to the IPM on CKT 41 (BRN) at connector C1 terminal C2. The voltage inputs are referenced to the module ground at connector C1 terminal D16 on CKT 451 (BLK/WHT). The IPM is wired to the Class 2 serial data line CKT 1807 (PPL) at connector C1 terminals C7 and C8. The various IPM input and output circuits are described in the corresponding areas as indicated on the IPM electrical schematics.
Battery Positive Voltage (B+) is provided from IGN SW fuse 20 in the Rear fuse Block on CKT 540 (ORN) to the RIM at connector C1 terminal A1. Ignition Positive Voltage (IGN1) is provided from IGN1 fuse 12 in the Rear fuse Block on CKT 1039 (PNK) at RIM connector C1 terminal A3. These voltage inputs are referenced to module ground at connector C1 terminals B7 and B8 on CKTs 1051 (BLK). The RIM is wired to the Class 2 serial data line CKT 1807 (PPL) at connector C2 terminals B3 and B4. The various RIM inputs and outputs are described in the corresponding functional areas as indicated on the RIM electrical schematics.
Aug 11, 2016 | Cadillac Cars & Trucks
What does invalid mean
1. Being without foundation in fact or truth: Indefensible, unjustified.
2. Lacking in effectiveness: Inadequate, weak.
3. Being without legal force or effect.
4. Suffering from a disease or disability: Sickly, disabled
5: Declared unfit for active military duty.
As you can see one has to have some information about the context before one can select what is meant.
In computer programs, an input is invalid if it does not conform with what is expected. If a function expects an integer number and you feed it a floating point number it rejects it as invalid.
Jan 02, 2014 | Office Equipment & Supplies
Asking for the PKU Code Where do i get this number
Finding a PUK (Personal Unblocking Key) number is not tough job. To find a PUK code all you have to do is call up on the customer care number and ask them to help you with the issue. Before they provide you the PUK code, they will ask you several questions. You need to give them the appropriate information. Customer care of your service provider are the only source from which can give you the PUK code.
At the time when you enter a wrong pin number three times. The phone asks you for a PUK number. The PUK code is generally eight digit number This PUK number is an unlocking code which helps you to unlock the phone and use it. If you enter a wrong PUK number 10 times than you simcard gets rejected. Then you will have to but a new simcard. It might happen that your phone might ask you for PUK2 after you enter your PUK number.
Aug 15, 2009 | LG Vu CU920 Cellular Phone
Please Solve this C++ Program
Write a program to prompt the user to input several lines of input. A line of inputs is terminated by '*'. For each readline of input the program should output:(use pointer notation for the array) . The total # of words . The lenght of the longest word in the line At the end the program should output: . The total number of words read in all lines of input . The lenght of the longest word read in all lines of input
Jan 19, 2009 | Computers & Internet
Invalid number
Fax machines do not work well or at all on digital lines. They are designed for analog lines, like the standard phone company line. You may have to install a dedicated fax line from your tel. company.
Jun 11, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Computers & Internet Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
