Question about Refrigerators
Tow dooe refrigerator and frezer, ice in the
Tow doors refrigerator and frezer, ice in the top part of the frezer what is the problem?
    Sergeant:
  • 340 Answers
Likely door gasket door out of alignment. or the defrost high limit switch is not opening in defrost when the evaporator get warm during defrost check the door gaskets good and clean. Tom
Posted on Jun 29, 2009
Ice in bottom of frezer
make sure your doorgasket is sealing correctly. if the water runs out it shows that the defrost heater is working.
Aug 07, 2009 | Frigidaire FRU17G4JW Refrigerator
Does not get cold enough to freeze ice at times . if i put ice creme in the frezer it becomes very soft. if i put bags of ioce in the frezer they will stay hard.. this with the control all the way up.
your door is probably not sealing properly. close the door with a dollar bill between the closed door if it comes out easy . that is your problem. you need a new door seal
Aug 02, 2009 | Refrigerators
Water leaks out of freezer once or twice per day
is there water frozen on the frezer floor.if yes your defrost drain is froze over.it only happens a few times a day because happening when its going into defrost,the water melts on the frezer evaporater then should go in the drain.if blocked it then runs on floor.you could turn of your refer for 8 hours or so.or get to the bottom of frezer behind back frezer panel[remove]and use a hair dryer to thaw drain use a weed eater line with a knott on an end to push thru and pull out the other side.the knott would clean any stuff in the drain line.ps watch out for water and electricty.i hope this helps God bless,tom
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not dropping the ice once it is frozen.
Yes there is a heater that releases the ice cubes from the tray as they are being elected. There is an overheat thermostate relay inseries with the element in the ice maker assembly. The element is installed in the metal housing that holds the tray.
If the cubes do not release the heater should remain on until they do. Suggest that you turn off the ice maker by lifting arm to off and wait several hours. Open door drop arm and observe. If the cubes remain stuck when ejector fingers attempt to eject and ice doesen't eject then heater is not coming on. Suggest replace ice maker. The parts are easily available and easy to replace!
Jan 15, 2009 | Whirlpool GS6NBEXR Side by Side...
Icemaker is not making ice
is there water in your icemaker.if so then its up to icemaker to do its part.frezer temps must be near 0 degrees.if no water in icemaker is the line in the back of the frezer frozen [top back where water passes thru frezer wall into frezer section.if its not frozen,am i then getting voltage to the water valve when the ice maker cycles.if not then icemaker is bad.if your ice bucket is on the door[whirlpool,kenmore]there are boards in the frezer section that can fail.i know that dosen't tell you what the problem is .but it does give you somthing to go on with.God bless ,tom
Jan 11, 2009 | Refrigerators
Ice Maker abruptly quit
is the ice bucket in the door ? if not and there is water or ice inthe maker and your frezer temps are right[close to 0]the its the ice maker.some maker have a moduel you can replace but the surest way is to replace the whole maker.if bucket in the door theirs other posibilties.God bless,tom
Jan 02, 2009 | Maytag MSD2754G Side by Side Refrigerator
Side by side freezer
check the fan in the frezer is it running and is there any frost on the back panel of the frezer
Nov 29, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
