Question about AOpen MX36LE-UN (91.89Q10.101) Motherboard
No display on monitor.
Motherboard lighted up,heat sink fan runs, i change around memory module remove power connection, disconnect all cd-roms/hard drive,clear cmos,and leave keyboard/and mouse connected.
  • 317 Answers
Re: no display on monitor.
More than likely you have a bad CPU. I've seen this several times.
Posted on Nov 07, 2007
0 characters
3 Points
Need parts for my awd9 mother board. heat sink for processor, wiring diagrams and wire harness. Also is a 480 power enough to run a invidia gen6 256 graphics?
you can get the power sup. at any computer store.the cpu heat sink you need to know the wattage of the cpu before you get the heat sink fan.And far as wiring diagram your book the came with the board has it if not you need to go to the web site of board to get it.All the plugs fit dvd or cd rom hard drive and motherboard have its own from the power sup. ok jim
Oct 25, 2013 | Abit AW9D-MAX Motherboard
All the lights come on when I switch on my HP Pavillion dv9600 but the screen is blank.
DO THIS FIRST - Perform a hard reset If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Actions to take after performing hard reset If no error message is displayed:
If a text error message is displayed, see Troubleshooting Error Messages on a Black Screen During Startup or Boot c02076104.jpg
Black Screen with No Error Messages Connect an external monitor c02076105.gif If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance. Disconnect all peripherals and repeat the hard reset Even though users are instructed to disconnect all peripheral devices from the notebook when doing a hard reset , some devices are often overlooked. c02069237.gif Double-check that all devices are disconnected including: external keyboard and mouse (wired or wireless), USB connected external drives and devices, thumb drives and flash drives, network storage devices, PC card, SD memory cards, express card, eSata connections, firewire or similar devices, printer, scanner, camera, port replicator, or docking station, any CD/DVD from the optical disc drive, and any media from the multi-card reader.B
Chris Thrash
Jan 10, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Pc running but wont recognize screen I have tried other screens but same result ,replaced video card still nothing on screen what else should I do
remove your memory card and wipe it clean with a clean cloth and insert the memory in the slot dont forget to remove all the addon card ide or sata cable power to hard his and cd drive restart the computer see if the display is ok if not remove the processor fan and the processor clean it with clean cloth and fix the processor to the socket also clean the heat sink and apply a thin layer of heat sink solvent and fix the heat sink tightly to the socket if the display doesnt come change your processor which suits the socket
Dec 15, 2010 | ASUS P5GC-MX/1333 Motherboard
No display in monitor when i switch on my pc, i can see display on monitor after switching on the cpu for 5 or 6 times
Hello sir, hi, check out the following: I'm assuming the things that you may have forgotten.
1. is the 4 pin 12V Molex power connector connected to the mother board? 2. did you use a a good and tested memory module? have this module tested first on another PC. 3. Is your memory slot free of dust and dirt? if not clean it up. 4. is you power supply fan and processor fan spins when power is on? 5. Try powering ONLY the motherboard connected to a video display, no sata/ide cable with a tested memory installed. 6. try another Power Supply box. 7. Is your processor mounted properly? 8. when you apply power look at the keyboard lights, 3 lights initial power on then 1 light the numlock led is on. 9. do you have a plugged in usb device, remove this device as you power on the motherboard. 10. do every thing again and double check.
if all else failed, bad mother board. have this checked by a technician.
Oct 18, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
Intel D101GGC freezes ramdoly
Well, these kind of problems are very tricky to diagnose. You said that you've tried replacing your RAM, HDD and also the Power Supply. If you're using multiple RAM modules for dual channel support, remove one of the modules and try to run the system with only one module in the slots. If it still doesn't work, try to switch the RAM module to another slot. Do the same with the second RAM module.
It can also happen if the IDE/SATA cables are faulty/worn out. Inspect them to see if any of the pins are loose/broken.
Another way to diagnose problems with HDDs is
1. Disconnect your Hard Drives completely,
2. Boot your computer with a Linux/XP live CD using your CD/DVD-ROM drive.
3. If it runs perfectly, then you can assume that the problem might be with the HDD or the SATA/IDE cables.
Let me know the results after you troubleshoot.
Aug 19, 2009 | Intel D101GGC Motherboard
Asus p5s800-vm MB has complete power lets monitor know
Disconnect the hard drives, cd/dvd drives and any expansion boards you have plugged into the mainboard. We want to remove as much as possible to see if we can eliminate the problem.Using the onboard video, start it up again, and see if it comes up. If it does, then its one of the items you disconnected. Power down and reattach one of the disconnected items and power up again. Did it come up? Keep in mind that we want to see the bios start up screen. Once you have attached all the items you will have found the bad component. Replace it. But lets say you didn't get a good system when you disconnected everything. Well, that narrows down the suspected bad items to: the mainboard, the power supply, the memory, or the cpu. The power supply has many voltages coming out of it, keep in mind that the drives, cd/dvd rom drives and fans use 12 volts for spin up. There are 3 other voltages used by the mainboard. I would replace the power supply next with a known good one. Then it gets a little costlier, the memory, then the cpu and then the mainboard. Stick with it. You'll find out which it is. Good Luck.
May 21, 2009 | ASUS P5S800-VM Motherboard
No video
Go to the Asus website and download the drivers for this board. It's most likely that it did not come with drivers installed. Hopefully this will fix the problem. Good luck.
Dec 23, 2008 | ASUS P4V8X-MX Motherboard
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
AOpen MX36LE-UN (91.89Q10.101) Motherboard Logo
74 people viewed this question
Top AOpen Motherboards Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you an AOpen Motherboard Expert? Answer questions, earn points and help others
