Question about TruTech LMD-5702RT Portable DVD Player
The DVD player does not recognize disc "No disc"
The player will spin the disc and occassionally start to read the disc and freeze. most of the time it reads no disc. Please send me any ideas to fix this. Thanks.
5 Suggested Answers
  • 286 Answers
SOURCE: dvd player doesn't recognize dvd's of any kind
jusguessin should call Toshiba quickly. The units have a 1 year warranty. Do not open the unit or it will void your warranty (I know, I do Toshiba warranty repairs on their recorders. If anything will make be void a warranty, it's a consumer who opens the unit and pokes around inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive. Clean the lense with a q-tip with a little windex on it. Work the head up and down gently. Reassemble and test. If problem presists, go buy a new one.
Posted on Feb 14, 2008
ruanelectron
  • 59 Answers
SOURCE: disc is spinning and not reading
what player do you have.
it can be the lazer thats dirty or the main board thats not taking in the info.
open the player.(remove the casing)
switch the player on
open the tray and then close it.(don't put a disc in.)
see if there is a red light shining at the lens.
if you see no red light your lazer is faulty.
if you do see a red light just take a cotton **** en gently rub it over the lens.
please email me at "ruanelectronics@gmail.com"
for more help
Posted on May 11, 2009
  • 7 Answers
SOURCE: Trutech portable DVD player says 'no disc' all the time
You have problem with lease assembly. It may work if you clean it. You may use laser cleaner disk or take it apart and clean the lens with alcohol.
Posted on Jul 27, 2009
  • 25 Answers
SOURCE: DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Posted on Feb 18, 2010
DVD player will not recognize any disc
That cd play will not read the format on the ****,you need to try a diff type of disc
Sep 04, 2012 | Panasonic Televison & Video
DVD spinning slow and get a 'No Disc' message
The problem sounds like the spindle motor is about to go out completely. If a disc does not spin or does not spin at it's proper speed the optical lens reading laser can not read the disc and you get a "no disc", or "disc not recognized" error message. On average a dvd will spin 3 times faster than a regular cd will. The following pictures will show you what these components look like.
Check around your local area to find what a service technician will charge to replace the part. On average it will usually cost between $60-90 dollars most of which is labor.
I hope this gives you some idea of what the problem is and how to solve it.
If you would not mind, please rate my help. I would greatly appreciate it. Thank you
Feb 07, 2010 | Televison & Video
My NAD cd/dvd T550 displays NO DISC.
I have the same problem. When I insert a disk, my NAD T 550 DVD player displays 'No Disc'. It started with new disks while still reading older disks, but at some time it stopped recognizing any disk. Did you receive any suggestion yet or has anyone a suggestion?
Jan 27, 2009 | NAD T550 DVD Player
No disc displayed
The disc won't spin until the unit recognizes that there is actually a disc there. Try cleaning the lens using a cotton swab and alcohol. If that fails, try playing a CD. If the CD plays, the optics are starting to fail as reading a DVD requires higher laser power.
Dan
Mar 19, 2008 | Cyberhome DVR 1600 DVD Recorder
Optima movie time DV10 not recognizing disc and making clicking sound
I have the very same issue. The dvd player makes a clicking sounds, spins, then stops...no disc. I have tried cleaning it and have also tried new dvds.
Mar 01, 2008 | Optoma MovieTime DV10 Multimedia Projector
DVD not reading but spinning
Are you using +R discs(not the -R)? Use Sony brand +R or try using a few +RW's and see if that corrects the problem.
Feb 23, 2008 | iLO DVD Recorder DVDR05
Invalid disk message sometimes and machine lock up
coby dvd-233 cd wouldn't spin invalid disc is displayed on the tv please help me solve this problem
Jan 21, 2008 | Coby DVD-233 DVD Player
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
A message appears saying "no disc" and DVD are not recognize anymore
If this unit has a built in DVD player, then the player's lens may need cleaning. There are lens cleaning discs available for this. If the unit does not have a built in player, then the same applies to your player & there is no problem with the projector itself.
Jul 10, 2007 | Optoma MovieTime DV10 Multimedia Projector
TruTech LMD-5702RT Portable DVD Player Logo
137 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
