Question about American Standard Cambridge 5' Americast Bathtub w/ Grab Bar Drillings & Le
Can't get the plug out to clean hair in drain
I have the same problem where I cannot get the plug unscrewed. The screw is stripped because it would not budge and I stripped it.. How do I get it off?? Can I drill the center of the screw? I also have a broken toothbrush head stuck in it because I was shoving it under the plug to pull up the hair. HELP!!!!!
    President:
  • 3,433 Answers
Get the new part first and do what you need to do .
Posted on Jun 29, 2009
  • Ned C Cook
    Ned C Cook Jun 29, 2009
    ok, It me a minute or ten but I see what you are trying to do now. The drain in the sink is plugged up. Under the sink there is the drain pipeOn the backside of the part that is before the trap, the part of drain attached to the sink, there is a rod that sticks out horizontally and attached to the verticle rod you use to open and close the drain. The horizontal ros has a nut holding it on the drain. Remove the nut and pull out the rod. Your drain stopper is now free when putting the rod back in, just make sure the slot in the stopper is facing such that the rod will go into it when istalled. Anything else? OH, get the tooth brush out.:)
How do I take the drain plug off so I can clean it out?
If the drain is one like this
https://www.plumbingsupply.com/images/foot-actuated-tub-closure.jpg
You can remove it by unscrewing the cap anticlockwise. You may need vise-grips. Pad the jaws with masking tape.
If it is one like this
http://www.mustknowhow.com/wp-content/uploads/2010/04/drain.jpg
You must remove the center screw and strainer. In extreme cases you may need to remove and replace the drain flange with a special wrench
http://images.meredith.com/diy/images/2009/02/p_SCP_167_08.jpg
In some locations there is no center screw to the strainer, which is all one piece with the flange. These cannot usually be removed without access to the big nut on the underside of the tub
More info here
http://www.familyhandyman.com/plumbing/drain-repair/unclog-a-bathtub-drain-without-chemicals/view-all
May 08, 2015 | Home
How to remove the spark plug and cleaning proceedure
Use the correct size plug spanner. Take off the lead and unscrew the plug. Clean it with a soft wire brush and carefully set the gap to .015 inch by carefully bending the side terminal. Screw the plug back in until it is tight. Do NOT overtighten or you will strip the plug's screw thread.
Feb 06, 2014 | 2011 Hero Honda Pleasure 100
Washing machine was not draining. unscrewed filter at bottom of front of machine. All water drained out but filter still screwed in. is supposed to be attatched or is it clogged with hair and should i pull...
It should pul lall the way out, there is probably nsomething stuck in the filter, you will have to persist in trying to pull it all the way out, make sure it is fully unscrewed anti-clockwise.
Nov 29, 2010 | Washing Machines
Peerless sink plug is clogged with hair. How do I
The plug is held in place by a rod that connects to the plug lever. Look under the sink where this rod enters into the drain. The rod is held in place with a cap that is screwed onto the drain pipe. Unscrew the cap, pull out the rod, and the plug with then lift out.
On some sinks, the plug can be twisted to release it from the plunger rod, you simply twist it until it unhooks. It it does not twist, then folow the first set of directions
May 02, 2009 | Peerless Industries Home
I am trying to remove the pop-up drain
To clean the drain simply remove the packing nut off the back of the pop-up assembly. This is located under the sink itself and will be on the back side of the chrome (might be plastic) pipe coming out of the drain hole. This nut is what is holding the rod in place. When you remove it be sure not to lose the ferule (nylon washer) inside. after the nut is off, you can pull the actual stopper out and have better access to the drain inside. Use a small hair remover (you can buy these at the "depot"), it has a long body with small "spines" coming off the sides to catch hair, to pull out hair. It should be long enough to get into the P-Trap. After you are satisfied you can put the stopper back in. Make sure the hole in the bottom of the stopper is lined up to catch the rod. Reassemble the packing nut with ferule and check for leaks. If you want to take the trap off be sure to have some 'pipe dope' on hand to reseal the threads. Teflon tape is not necessary. Reassemble the trap and check for leaks and you should be good to go. Good luck :).
Mar 21, 2009 | Home
American Standard Cambridge 5' Americast Bathtub w/ Grab Bar Drillings & Le Logo
876 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
Mike
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
