Question about Dell 1720dn Laser Printer
Dell 1720 printer prints junk first page with only ?Z@ troofpaN.
I have the same problem. The first sheet only has ?Z@ troofpaN printed on the first line, then the other sheets are normal. I tried reloading the print driver to no avail. Enough people have this problem to justify Dell fixing it.
  • 9 Answers
This is a issue with the printer drive that windows is holding, not the printer. To Un-install your printer drive the correct way, goto add/remove programs, and un-install the printer there, then open up your printer control panel and right click where there is no printer. In the right click menu click server properties, then click the drivers tab, then remove the 1720/1720dn drivers there. A system restart will be necessary in most cases before it will let you remove the drivers(the Microsoft print spooler is to blame here for that). If this still doesn't work for you, then install a hp laserjet 4 driver and see if it does the same thing. if not, then it is something with the driver/spooler, if so, then it is the MCU of the printer, and you might want to look at buying a new printer.
Posted on Aug 22, 2009
How do i print a confige page on a dell 1720
Turn off the printer
Open the front cover
Press and hold the Continue button as you turn on the printer - all the lights will cycle
Release Continue button and close the front cover
Press the Continue button until the lights cycle and the configuration page will print
Jun 25, 2014 | Dell 1720dn Laser Printer
My dell 1720 printer prints streaks on the right side of every sheet. i replaced the toner. No change.
Remove the toner and the paper tray and open every door on the printer. Take a can of air and blow out every nook and cranny in the printer. Check and carefully wipe all rollers. There a fuser kit in the printer, likely in the back. If you feel comfortable with it, remove the fuser kit and use a can of air to continue cleaning. Reassemble the printer and run a few test pages, it may look like a bigger mess for the first few pages (up to 25). However, as you run the pages the print should clear up. If you still have a streaks on the pages, you will likely need to order an maintenance kit from dell. This kit should include the fuse, rollers and other replacement parts for the printer.
I hope this has helped you
Aug 31, 2011 | Dell Laser 1720 Printer
How do I Adjust the Printer Margins for Dell 1720 I am printing on insurance forms and the print is too high and to the right
I have found a good manual that can help you easily with the help of pictures.
Click on the link below to access it :
ftp://ftp.lexmark.com/depot/Dell/Dell_1720_Depot_rev061807.pdf
In case of further help let me know
Mar 21, 2010 | Dell Laser 1720 Printer
How do I print duplex on the Dell 1720?
You need to visit the Printer in Control Panel - Printers and double click on the 1720 icon and go through the setup tabs and select Duplex Printing. If you only want to print duplex occasionally you can select duplex from the print options presented when you print a document by selecting the Preferences or Setup button when the Print Dailoig box appears.
Nov 12, 2009 | Dell 5100cn Laser Printer
DELL 1720 PRINTER PRINTS VERY SLOWLY.
Whenever I have a customer tell me their printer seems to be running slower, 9 times out of 10 its what they're trying to print...not the printer. Heres a couple of things to do and ask yourself. First I'd do a test print from the printer itself. Does it kick it right out? Then go to the printer folder on the computer, right click on the printer, go to properties..click print test page. Does that come out pretty quick? Okay if they seem relatively fast then its beginning to look like something other than the printer. Try printing the job that seems to run slow. Then try printing from a different program. Is there a difference in speed? The job that prints slow may have graphics or require more memory then it use to. Perhaps you changed the graphics content on the page and the printerr is taking more time to process it. Adding more memory to the printer can help that.
Did you make any software change to the printer about the same time you noticed the slow down?
Have you changed the font color in the computer to something other than black for that particular print job? I've seen monochrome (black and white) laser printers slow down because its trying to convert the job to say violet or some other color. Its a black text printer and apparently printing color confuses it ..lol My bet is..if you really sit down and think back...something changed in the content of what your printing thats taking it longer to process it. Hope this helps!
Jul 10, 2009 | Dell Office Equipment & Supplies
How do I find the page count on my Dell 1720 printer?
  1. Turn off the printer.
  2. Open the front cover.
  3. Press and hold the Continue button continue_button_0.jpg as you turn on the printer.
    All the lights cycle.
  4. Release the Continue button continue_button_0.jpg.
  5. Close the front cover.
    The light sequence representing the Home menu is displayed.
  6. Press the Continue button continue_button_0.jpg until all the lights cycle.
    The Printer Settings Configuration sheet prints.
Jun 29, 2009 | Dell 1720dn Laser Printer
My Dell 1720 printer will print a first page of one short line of icons, then print the actual items sent to printer. As it is printing the status window shows printer off line and no toner level.
Chances are the formatter board on your printer is going out, if it is still under warranty i'd call dell otherwise prob cheaper to get a new one
Jun 25, 2009 | Dell Office Equipment & Supplies
Dell 1720 flashinf replace drum- error.
The second link was the helpful information. Also, to cut through all of that --
If you need to reset the counter:
1. Remove drum kit with toner
2. Make sure all print jobs are flushed otherwise whatever has been sent and not printed will come spewing out.
3. Hold down CANCEL Button until all lights flash through.
4. Slide the drum kit and toner properly into the Printer.
done.
Mar 03, 2009 | Dell 1720dn Laser Printer
Dell 1720 usb port printing problem
You can get a usb adapter to printer comp ports on ebay eBayeBay
Sep 20, 2017 | Office Equipment & Supplies
Printer prints first page with strange nonsensical characters
I would move the printer to another computer. See if the problem follows. I have seen the issue a few times with issues in normal.dot but also in other office applications.
Problem I'm fighting with on my 1720 is its printing extra pages between pages. basically print a 5 page document and get an 8/9 page final with the extra blank pages. Think its a user error but could be machine related. going to try it on another PC and see what happens.
May 28, 2008 | Dell 1720dn Laser Printer
Dell 1720dn Laser Printer Logo
173 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
