Question about Canon PIXMA MP150 All-In-One InkJet Printer
Unasble to print
When start up printer I get Message E then a 5 and still cannot print there is also a message on screen Black and Colour cartridge not recognised. The printer has had the cartridges in use approx 2weeks and not overused
  • pezamingi Nov 12, 2007
    Printer functioning fine, then suddenly E5 error message indicating both cartridges not recognised. Cartridges still contain plenty of ink. Replaced black cartridge, but not colour cartridge. Same E5 error message appeared.
  • Pronoun Dec 13, 2007
    I have the SAME problem. I changed the black cartridge and now I keep getting the infamous E and then 5 blinking. Also the Color Ink is blinking. I press Black but it doesn't do a thing, the color ink light keeps blinking. The color ink is empty (I never use color) so I removed it completely but it made no difference. Now what do I do?
Aldous,
This solution doesn't work. I've tried it about ten times and the E5 error message won't go away. I can't even scan.
Posted on Jun 13, 2008
    Scholar:
  • 41 Answers
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Posted on Feb 11, 2008
I have message "Cartridge Error". I have established that the colour cartridge seems to be faulty. It is old and only replaced once because I do not actually need colour, use mainly black printing onl
Hi and welcome to fixya
You can print black pages with the color cartage. HOW ? just when you select the size of the paper A4 then ther is an option of colored printing or black if you have ink in the color cartage then it can be done that you can print black pages with that cartage
thanks hope that will be helpful
Dec 08, 2012 | HP Officejet 5610 All-In-One InkJet...
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
My printer is not printing the message just some parts
You might find that it is either printing the colour parts and not printing the black parts or it is printing the black parts but not the colour parts.
In this case you need to replace the ink cartridge that your printer is not printing. Either black or colour.
Ensure to get the exact same ink cartridges so that they work 100% in your make and model of printer.
All the best!
damnor01
Feb 01, 2011 | Lexmark Office Equipment & Supplies
Hi there, Can I print in Black & White when I ran out one of colour ink catridges??? On Brother website it says that you can. According to their advice the Error message shoud come up on LCD screen...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up you should be able to tell the printer to print in black and white in your page setup or print properties portion when you go to print your page.
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | Brother MFC 6490CW InkJet Printer
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
My printer will not accept a new black cartridge.
ITS NOT THE BLACK CARTRIDGE!!! Try changing the colour cartridge and see what happens. When a 9600 checks ink levels it does the black ink first, then the colour, if the colour is low it goes back and checks the black again but will constantly give an error message for the black cartridge. Sounds bizarre but try just the black cartridge in with no colour. print a test page in black only, if that does not print then it is a fault. Also make sure the driver is updated!!!
Feb 16, 2009 | HP DeskJet 9650 InkJet Printer
Ink cartridge problems
exchanged the black cartridge (57): the printer told me there was a problem with it, that I should remove it and re-insert it. I did, the ink button still blicks. After several efforts the printer started to work again, printed one document and then told me there was a problem with the colour cartridge. I removed it, re-inserted it several times. Finally a test page was printed - everything was okay.
Then the printer refused to print anything - the yellow LED lamp blicks continuously. Have turned the printer on and off, have also shut down the computer and re-started.
The only thing that will work now is the black cartridge, if I remove the colour one.
May 08, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Tri Colour cartridge inserted is not intended for use in this printer msg
Try to clean the print cartridge contact points with a good rubber eraser and clean the printer side cartridge contacts with good lint free cotton cloth. Then first insert Black cartridge and then colour cartridge. Use some more pressure while attaching the cartridges.
Apr 22, 2008 | HP PSC 1315 All-In-One InkJet Printer
My printer won't print because there is more than one inktank of the same colour
There are 2 types of black cartridge, CLI-8Bk Black Ink Tank & PGI-5 Pigment Black Ink Tank. These must be installed in the correct order as below. Have you replaced a black cartridge & perhaps used a different type? Here is a link you can get more info from: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=11994
Aug 05, 2007 | Canon PIXMA iP5200R InkJet Photo Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
