Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Honda HRR21 mower self-propelled unit not working.
  • 11 Answers
SOURCE: SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Posted on Mar 15, 2009
  • 7 Answers
SOURCE: yardman push mower self propell not working
check to see if it is belt or gear driven
Posted on May 02, 2009
  • 59 Answers
SOURCE: Have honda harmony 11 HR 216 that stopped being
it has a belt look under the mower
Posted on Jun 26, 2009
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
HOW DO I REPLACE THE SELF PROPELLED ON MY HONDA MOWER. MODEL HRX217HXA
http://www.lawnsite.com/showthread.php?t=281234
Good pictures on this link to follow. I found it eaiser if you put your mower on a work bench or 2 sawhorse with plywood on them. Read everything on the link for your plan before you start. When you finish you will feel you can fix anything on the mower. Hope this will do the trick for you. Good luck!
Sep 21, 2014 | Honda HRX217VKA Lawnmower
How to replace drive belt on Honda self propelled mower
Remove the plastic cover for the drive belt. Replace the belt.
Jul 08, 2013 | Garden
Honda self propell
Google model number parts. Clean pulleys, replace belt.
May 05, 2013 | Honda Garden
Honda harmony self propelled cable snapped at end
Get a replacement cable, part number should be in your user manual...when you get the cable it should have directions on how to replace.
Sep 08, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Aug 05, 2009 | Garden
Self propel won't allow the mower to back up freely. works fine moving forward.
either the wire going to the transmission is not tight enough and need adjustment or belt needs replaceing
May 26, 2009 | Mtd 22" White Outdoor Self Propelled High...
Apr 29, 2009 | Garden
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
564 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
