Question about Mtd 22" Yard Machine Push Mower
Wiring electric mower switch
The wires on the electric mower came off. what order do they go back on?
Craftsman 917289101 wiring diagram
The diagram will not be of much help. Try a an ohm meter for continuity, wire by wire with ground.
Jul 06, 2015 | Craftsman Garden
My pto is on all the time on my Toro zero turn. Blades are engaged when I start the engine even though the switch is in the off position? What would cause this?
Haven't had your particular problem, but my my blades would not turn when I pulled the PTO control knob. Turned out to be a bad PTO switch. Mechanic replaced the switch and it worked fine thereafter.
Dec 26, 2014 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
How do i remove a electric clutch brake for the pto switch on a snapper riding mower?
You can jump the wires to the switch to see if is the switch itself. You will have a ground, a 12 v supply and a wire to the option. If you power up the device with a jumper wire, don't forget device needs ground too, and the device engages, you will just need to order the switch, or if you are a bit inventive, create one, not recommend
Aug 15, 2014 | Garden
Mower blades will not engage on my STX38
Turn the key switch to the on position. Pull the blade engagement switch on.Look under the engine and find the electric clutch. Disconnect the wire connection there and while using an ohm meter, check and see if there is 12 volts on one of the wires. If so, then the clutch may be your problem. If not, then you need to trace back the wire from the clutch connection and find out why there is no voltage
Sep 06, 2013 | John Deere Pto Clutch For Stx38 And Stx46...
I pulled out the pug to recharge the starter for key start, and lost the outer plastic casing to plug it back in. Can I order the casing for the exposed prongs
The 10640 model does not have an electric start that I can see. Are you sure you have to model number correct? The 10642 and 10642C models are electric start. I will use the 10642 as a parts reference.
The electrical assembly is here:
http://www.partstree.com/parts/?lc=lawn_boy&mn=10642%2C+20in+Mulching%2FRear+Bagging+Lawn+Mower%2C+2009+%28SN+290000001-290999999%29&dn=3361337A-392215-0007
Where did you pull the wires out from? The battery box? The mower harness? The switch?
From looking at the parts available you should be able to figure out which part you need to replace.
Kelly
May 22, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I have a John Deere l130 and the mower blades engage when I start the engine even when the PTO switch is off. Any suggestions?
sounds like you have feed going directly from switch as soon as you turn ingition to start mode ?
check wiring back from electric clutch to main switch
possible 2 wires have been placed on main switch instead of pto switch ?
or you have a crossed circuit somewhere (that is feed from another live circuit) not directly connected and its ended up at electric clutch as soon as you liven main circuit
a wiring diagram may help
check with www.johndeere.com
or www.jdparts and enter their site load your model and type
and go to electrical system and print out a copy of wiring diagarm
you may need to supply and user name and apply for password from john deere via their site apply on line
its a good site for info and parts diagrams
cheers hope it helps
paul
Aug 05, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
Need wiring diagram for black and decker mower 8000 type 8
Try goggling by " wiring diagram Make Model #" and check the differnt sites. Usually you can come up with a downloadable manual
Jun 28, 2009 | Black & Decker 19" Electric Lawnhog...
Need wire schematic for starter switch
I am holding the switch part (INDAK 681064) with the black pushbutton switch to the right.
The two wires on the top are Red then White. The two wires on the bottom are both black.
Apr 10, 2009 | Black & Decker 19" Electric Lawnhog...
Wiring problem
its unsafe to hot wire the switch. contact me at 204-783-7294 i will send you a wiring diagram ask for dennis
May 05, 2008 | Black & Decker 19" Electric Lawnhog...
Mtd 22" Yard Machine Push Mower Logo
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
