Home | Poulan | Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin | 2375 poulan chainsaw tha...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Problem for Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
2375 poulan chainsaw that willnot lubricate chain
By patrickg461 on Jun 29, 2009
not lubricating
Best Solution
posted on Jun 29, 2009
Very Helpful)
mrfixit-jerr
Rank: Guru  Tools - Building & Power  Expert
Rating: 94%, 7015 votes
hello sir, what i would do is remove the bar and chain.in the side of the bar are a couple of holes that feed oil from the saw into the bar grooves.make sure these are clean of any debris.you can use solvent and a small drill bit to clean out holes.than look at the saw where there is usually a wear plate and make sure the groove there is also free of debris.lastly i would start the saw without the bar and chain and look for oil coming from the groove area described above.if nothing coming out than you have a problem with saw motor and would have to go deeper into it,you can also try rinsing out tank with solvent and running engine to see if fluid comes out.hope this helps,MrFixIt, oh could you please rate this solution,thank you.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Poulan Wild Thing 2375 18" Gas
Questions and Unsolved Problems for Poulan Wild Thing 2375 18" Gas
Do you recommend Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin?
Answer
Answer
I need a diagram for a fuel system on a Mcculluch 38cc mac cat....
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Poulan Wild Thing 2375 18" Gas...:
Top Chain Saw Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Chain Saw Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
