Question about Maytag Atlantis MAV6260AWW Top Load Washer
What is the product capacity of older Maytag washer A412
I researched the exact same question recently and found on a website somewhere that it is 3.2 cu ft.
Posted on Jul 22, 2009
How do I find out the cubic feet for Maytag washer model A412?
Calculate it yourself: Place a straight edge across the top of the unit. Measure the height from the bottom of the tub to the bottom of the straight edge. Then measure the width of the inside center of the tub and take half that number. Then use the formula below to calculate it. For example. Height 30 inches, Width 28 inches (half of 28 = 14).
V = (3.1416 x (14 x 14) x 30)/1728
= (3.1416 x 196 x 30)/1728
= 18498.48/1728
= 10.70 cubic feet.
Mar 02, 2015 | Maytag Washing Machines
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
I just purchased a Maytag centennial washer. I just love it the Maytag products arethe best. Question I am using the HE detergents as the book suggests, however how much bleach do I use?
According to page 6 of the manual for the "3 cu. ft. Capacity Maytag® Centennial® Top Load Washer" and page 8 of the manual for the "Centennial® High-Efficiency Top Load Washer", not more than 1 cup (250 ml) should be used in either machine.
Also, it should be added to the dispenser cup on the front left of the machine - not directly to the wash as it will interfere with the detergents ability to clean the clothes.
I hope this helps & good luck. Please rate my reply. Thanks.
Apr 20, 2011 | Maytag Centennial MTW5800TW Top Load...
Just trying to find out drum capacity of my maytag heavy duty super capacity 7 cycle washer. Please help
Check the tag where you find the model and serial number, they often list it there. Your owners manual should tell you as well. You might have to call whirlpool (maytag), I cannot find the capacity listed on the tech info. Good luck.
Sep 23, 2010 | Maytag LAT2600A Top Load Washer
Maytag washer will not agitate
A Maytag A412 is well over 20 years old....
Best guess is a corroded upper drive shaft, the one that the agitator is mounted on. Certainly it can be called a transmission problem.
Jun 28, 2017 | Maytag Washing Machines
I have an older maytag washer. It fills over the
I had the same problem on an older Maytag washer (A412 series?). The solution is easy...but a bit dirty. The problem is that your level switch, which is actually a pressure switch, is not actuating because its sensing line is plugged. The line usually plugs at the sensing line manifold (larger diameter tube) with washer "gunk" or slime near its connection to the drum. Note that there are not that many connections to the drum, so you should be able to find it and remove it. Access to the front interior of the washer will be necessary (its easy...the front panel rotates up and off). Access to the top instrument/control panel may be necessary to unhook the sensing line from the pressure switch if complete purging of the line is necessary. Take care when working with the pressure switch for their internals can be easily damaged.
Oct 04, 2009 | Maytag Washing Machines
Looking for capacity on my older Maytag washer
the capacity of your machine is six cubic feet. That is a box 2 feet by 2 feet by 18 inches.
Apr 11, 2009 | Washing Machines
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
Maytag a412 wiring for drive motor.
look inside the console the wiring diagram will be in there
May 02, 2008 | Maytag MAT13MN Top Load Washer
Maytag Atlantis MAV6260AWW Top Load Washer Logo
926 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
