Question about Toshiba Projector lamp Projector Lamp for TLP T520
Toshiba TDP-SP1 Projector fan error
I get the same fan error i never blew it out with canned air. The air out of the exhaust is warm but not hot, the lamp stays on for about 30 seconds then turns off.
JayBlair
  • 328 Answers
SOURCE: Projector Lamps for the Toshiba TDP-MT8 DLP
Have you contacted Toshiba? They will sell you a new fan. It is possible the power supply has a problem. Bulbs usually have a 90 day warranty. Contact where you bought the bulb. Prices are dropping rapidly for new projectors. Yoiu can buy a new oen for under 500.00.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 08, 2007
  • 7 Answers
SOURCE: Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Posted on Apr 06, 2008
  • 17 Answers
SOURCE: standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Posted on Jul 17, 2008
SOURCE: Toshiba TDP-T90 projector, lamp
I have the same problem. The lamp cover has a tab that sticks up about 1/2 inch. When you close the lamp cover the tab presses on a wire that allows power to the lamp. You can hear a 'click' as you close the cover slowly. My tab kept bending over preventing it from depressing the wire. I've straightened it several times to where now it broke off to where it wouldn't work at all.
I fixed the problem by clipping off the tab, inserting it in the bulb case to press the wire and taped the tab in place.
Posted on Dec 02, 2008
projdoc
  • 2237 Answers
SOURCE: Toshiba TDP-SP1 Data Projector Pink Tint
go into menu and make sure input is computer and not rgb component. or just reset to factory defaults.
Posted on Jul 30, 2009
Gets hot shuts down its toshiba TDP-SP1 how can i resolve it?? do i need to change cooler?
Make sure filters are cleaned. Use a vacuum so you don't spread dust around inside your projector. Make sure the projector can "breathe"; has room around it.
Nov 04, 2013 | Toshiba Office Equipment & Supplies
My TDP- T91A gets hot on one side is ther two fans in this projector or just one? I hear one fan but it seems to get pretty hot on the other side of the projector. I just received this and it is new to me....
Lamp life is affected by a lot of things. Is the projector mobile or is it permanent mount? How many hours a day is the projector on? There is no set time for bulb replacement. When it burns out it's a good idea to have a replacement already to go when needed. If the projector gets too hot, it will shut itself down as a safety precaution.
Jan 19, 2018 | Toshiba TDP-T91A DLP Projector
My projector is showing multiple white dots, looks like lots of small stars all over the screen when projected to screens. is this mean I need to replace the lamp? TDP-XP1 model.
The link to the article explains the the cause of the white syndrome none of the previous internet experts have a correct solution. I have the same problem the link to the article attached is for a Mitsubishi projector but all the chips are the same. http://www.fixyourdlp.com/2012/04/26/solve-the-mitsubishi-white-dot-problem-for-under-200/
Oct 19, 2010 | Toshiba TDP-SP1 DLP Projector
TD9-S81 no power when data projector comes on
no leds? bad power supply. leds but no fans? bad button panel or main board. led and fans but no light? colorwheel or ballast.
Sep 18, 2009 | Toshiba TDP-S81U DLP Projector with...
Jul 30, 2009 | Toshiba TDP-SP1 DLP Projector
Toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Jan 31, 2009 | Toshiba TDP-SC25U Multimedia Projector
FAN ERROR BUT THE FANS WORK
There are air flow sensors in the unit as well which you may have blocked up when you blew out the fans. If those sensors do not detect air flow, the assumption is that there is a fan error. Try removing the fan and cleaning the entire air flow path.
Dan
Aug 26, 2008 | Toshiba TLP-S10 Multimedia Projector
Toshiba Projector lamp Projector Lamp for TLP T520 Logo
660 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
