Question about Cuisinart Brew Central 12-cup Coffee Maker
I have lost the manual for the Cuisinart Brew Central, model CBC-00, coffee maker. My question is this: What the "carafe temp" knob does with L and H selections? I assume it is to select the carafe itself to stay on a low or high temperature but not sure since I have not owned a coffee maker with this feature on it. Thank you very much.
  • 85 Answers
Hello pdmkali,
Your assumption about the carafe temps is correct. The middle position gives you a medium temp, of course. I use it on low so that I don't burn my lips and tongue when I drink my coffee. Thank you for the opportunity to answer your question. If it is helpful, please leave positive feedback for me. It is appreciated. Regards, NormanZ :o)
Posted on Jul 08, 2009
In my CBC-00, there was a hard filter inside the filterholder basket. It accidently got thrown away and now I cannot find a replacement online. Any ideas about how to find one? Thanks!
Contact the manufacturer directly and see what they can do. We have no other resources here. If this uses a standard cone filter you can buy a generic on line. I have one in use right now.
Jul 20, 2016 | Cuisinart Brew Central Coffeemaker 12 Cup...
My coffee pot is turning itself off several minutes after brewing
sounds like the thermistor is detecting an over the operating temperature and is shutting down the power to prevent a fire.
Cost of repair if out of warranty is not worth getting serviced.
Apr 29, 2016 | Cuisinart Brew Central Coffeemaker 12 Cup...
Cuisinart CBC-00 series coffee maker seems to have lost power
Yes it has a short. Mine did the same. Cost to much to fix, cheaper To buy new one, if under 3 years old cuisinart will replace for $10 shipping charge. 1-800-726-0190
Jun 28, 2010 | Cuisinart DCC-1200 Coffee Maker
Cuisinart COD-4000 Stopped brewing coffee; lost clock and timing
I have no solution, however I have the same problem. Wondering if you have resolved the problem yet?
Feb 16, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
Not brewing. Add water and coffee, switch to the brew selection and the water/coffee does not flow. The machine heat ups and starts processing noise.
Make sure the lid is on the carafe.
Make sure you are not using a paper filter and a gold tone filter at the same time.
Make sure the carafe lid is down all the way and that the center knob of the carafe lid is making contact with the spring at the bottom of the filter basket.
If the above conditions have been met, then decalcify your coffeemaker by running 1/3 carafe worth of vinegar and 2/3 carafe worth of water through your coffeemaker - use the self-clean button to do this - will take about 35 minutes.
Aug 30, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Slow to brew
Aug 23, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 18, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Open Questions:
See all Cuisinart Brew Central 12-cup Coffee Maker Questions
Cuisinart Brew Central 12-cup Coffee Maker Logo
857 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
