Question about Poulan Garden
I have a poulan pro 331 trimmer. The primer bulb stays in and the trimmer will not start. What could be the problem please any info on this would be greatly appreciated.
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jul 02, 2009
  • Jim Parker
    Jim Parker Jul 03, 2009
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Poulan P2500 weedeater want start
change over the fuel lines on the carby
Mar 24, 2016 | Poulan P2500 17" Gas Trimmer
Poulan ym20cs won't stay running
Sounds like it needs carb adjusted and/or rebuilt.
Jun 24, 2014 | Poulan Garden
Carburetor change
Primer bulbs pull fuel from the carb, into the bulb and dumps it back to the tank, if you have re connected the hoses to the primer the wrong way around it will try to force fuel into the carb and make it flood.
Jun 01, 2013 | Poulan Garden
I have a Poulan 3312 Pro, the primer bulb opped off...how do I re-attach it?
You may have to get a new one that has more flexibility and will stay in place. External bulb assemblies snap in place and the ones on top of the carburetor of course have a metal retaining ring with 2 screws holding the primer bulb to the primer base.
Aug 25, 2010 | Poulan Garden
My Poulan Pro weed trimmer SM132 does not run. I replaced the primer bulb and spark plug and it ran fine for 10 minutes. Now it will only start with the choke on and dies immediately. It will not start...
The primer does require two lines attached as it is a Walbro style primer. All four SM132 models uses the WT628 Carb. Since the trimmer ran 10 minutes then you have got all the lines connected right. Mostly you got trash in your carb or it simply needs rebuilding as the diaphragm may have pin hole in it or the check valves are worn out. Depending on the age and use of your unit you may also have a sticking piston ring.
Aug 23, 2009 | Poulan Garden
LOOKING FOR INFORMATION ON FUEL LINE ROUTING CONNECTIONS. FROM FILTER TO PRIMER BULB, TO CARB CONNECTIONS AND THEN TO RETURN BACK TO FUEL TANK.
most trimmer fuel lines run from line in tank with pick up filter to bottom of carby then out of top of carby to inlet on primer usually the smaller tube then out of the longer tube on the primer and back to the tank.
Jul 21, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Poulan GHT-22 Hedge Trimmer The Primer Button Will Not Inflate
When changing the fuel lines did you get them back in the correct location? This would prevent the bulb from working. Also, if the bulb is old and brittle or leaking, would also cause hard start or leaks around the handle.
Jun 18, 2017 | Poulan Garden
Featherlite trimmer primer bulb
Hi
Check the hoses from primer bulb to the carb.
best regards savumihai71
Dec 09, 2008 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
424 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
