Question about Whirlpool LEQ8000JQ Electric Dryer
Griding noise while spinning. the unit heats and spins but makes grinding noise as if the drum were off track
  • 97 Answers
Hello Friend, Your problem is very simple to fix. You need to replace the Rear drum support rollers. To replace the Rear drum support rollers just remove front of dryer body exposing the drum, look under the drum and you will see the belt and tention wheel in front of the motor. Now, release the tention on the belt and remove belt from motor shaft. At this point you can remove the drum up and out of the dryer cabinet. Look towards the rear of the dryer cabinet and you will see the rear drum rollers. The roller on the left has a support strap held on by a press on clip. just pry this clip off and remove support bar. Now there will be a plactic triangular clip holding the roller in place. Just remove the plastic clip and replace roller. The roller on the right just has the triangle plastic clip just remove and replace that roller as well. Be sure to lubricate the roller shafts with some 3 in one oil prior to re-installing the new rollers. Make sure you re-install all of the retaining clips. After re-assymbly of your dryer if should run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks.
Posted on Jun 29, 2009
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
What is wrong with my washing machine?
remove the agitator and look for coins , buttons and other objects jamming the spin , agitator and drum
Dec 12, 2015 | Electrolux Washing Machines
As it spins very slowly back and forth it also makes the grinding squeeking noise.
Hi Robert.
What you describe sound like a distorted drum and/or collapsed bearings. The grinding noise is typical of bearings which are worn out, and the squeaking can come from the drum rubbing on the door seal.
Check if the inner drum is loose and flops up and down. Also spin the drum by hand and see if it's touching the rubber door seal anywhere. If it spins freely but make a growling noise your bearings need to be replaced..
Neither of these situations are good. A serviceman is probably required to know for sure.
Good luck.
Nomess
Check that drum (2nd below) is not rubbing on this door seal
Drum should rotate quietly and smoothly
Jan 13, 2015 | Washing Machines
Grinding noise when drum spins
they r hard rubber attachments that keep the tumbler from grinding metal to metal. go to local appliance center 15bucks a set. easy fix
Mar 17, 2013 | Maytag ADE7005AYW Dryer
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
Loud noise when it spins
Sounds like main drum bearing noise, try turning the drum by hand, if it feels rough or you can hear it grinding or rumbling, then it is the the main bearings that have failed..
You will probably need to call an engineer.
Dec 03, 2008 | Washing Machines
Very loud noise as drum is spinning
Hi, I think that the bearings may be wearing down and need to be replaced. Or the belt may be faulty and needs replacing.
To tell if the bearings are wearing down or need replacing, turn the drum by hand when it is empty and it will make like a grinding noise.
If the belt is torn, frayed or coming off the motor you will need to physically look.
Nov 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing machine problems
Sounds like the bearings in the drum may have failed, was it vibrating irratic on full spin before it stopped?
Mar 07, 2008 | Washing Machines
Dryer Making a Grinding Noise
The grinding noise is probably a worn out roller or the central bearing in the back. The center of the drum in the back has a part called a bearing which screws onto the back of the drum and has a stub which sticks out. The stub then goes into a bearing hole in the back panel of the dryer. If you are handy, you could try to replace yourself. I did it once. While you are at it, check the drum belt which goes around the drum and makes it spin. Replace it if looks like it has wear.
Feb 01, 2008 | Kenmore 63942 Dryer
Whirlpool LEQ8000JQ Electric Dryer Logo
332 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
