Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
How to put the string back into the coil - Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
    Problem Solver:
A lot of people don't even bother trying to fix a recoil because they don't cost much to replace. maybe $10. but if you try make sure you don't let that coil unwrap or you will have a lot worse problems then just the string :p
If you can successfully get the cover off without allowing the coil to come loose then simply just wrap the string back up.
Posted on Jul 22, 2009
The pull string isn't pulling back into
while it is apart turn it counter clockwise. you will be able to tell in the first few turns if your going in the right direction
Oct 11, 2014 | Garden
Tip
How to string an electric guitar
I'm writing this tutorial to help new guitarists string their electric guitars.<br /><br />The first step is to purchase some strings from your nearest music store, depending on the type of music you want to play the string gage will be different. If you want to play heavier music such as metal then I suggest using a heavier gage of string. If you want to play calmer music such as indie, or maybe soft rock I suggest a lighter gage.<br /><br />Next make sure and remove <span style="font-weight: bold;">ALL</span> existing strings. The best way to take off the old strings is to simply loosen them up then cut them right in the middle with wire cutters. Then just pull the left end through the tuning knobs, and the right end through the back of the guitar (Note where the strings come out of the back).<br /><br />After you have removed all the strings its time to put on the new ones. Start with the string closest to the top of the guitar. On your string package you can reference by color which string is which. Find your string then run the sharp end through the back of the guitar in the hole relative to the string you are putting in (These holes in the back are the same holes the old strings came out of). Run the string all the way through so that it is pulled tightly into the back. Now place the sharp end of the string through its relative tuning knob at the top of the guitar. You should pull enough through so that when you pull the string up off the neck there is a gap of about one foot. Now turn the tuning knob clockwise until the string is relatively tight against the neck and it has wrapped around the knob 3-5 times. Now cut the excess string that is coming out of the tuning knob but leave about 1 inch in case you want to lower the tuning. <br /><br />Do the same thing for all your strings, then tune them with either a digital tuner or by ear if you can. You can purchase a cheap digital tuner for around $20 at your nearest music store.<br /><br />Enjoy!!
on May 16, 2011 | Yamaha Electric Guitar
Pull string
you might have you coil set to close to the flywheel and the coil is not letting the flywheel spin like it is suposto sotheir for you string id to tin\ght when you hace the hood on so reagap the coil and sett it a little farther back from the flywheel by not to far back
May 14, 2013 | Mtd 22" Yard Machine Push Mower
How to change the strings onthe epiphone professional deluxe mandolin
You can slide the silver plate straight back by gently pushing it from the top with your fingers. Once it slides off you will then be able to see the hooks that you put the new strings on (loop end strings). Once strings are tightened, you slide the cover back on the same way you slid it off. There is a small piece of felt glued to the cover. Be careful not to knock it loose when you are putting the cover on.
One other tip, change one string at a time instead of pulling all of them off at once. The bridge will come loose if you take all the strings off at once (it is not glued to the mandolin).
Feb 17, 2012 | Epiphone MM-50E Professional Mandolin
Pull string to start broke and now the coil is off, how do i put it back together
I have the same problem! I need to recoil, place in properly and assmble the crankcase. I'm doing something wrong. I haven't found the problem yet.
Jun 21, 2011 | Quad 47 cc / 49 cc Pocket Mini Bike...
The string would not recoil. I took it out of the case and got it to work, but when I put it back in the case, it won't work.
Make sure when you are tightening the screws back down you arent restricting the recoil motion of the spring that coils the rope back in , tighten a little at a time and check as you go .
Feb 24, 2011 | Garden
Hi I have a mtd yardman 55/45 ym 5518 s mower and the string has snapped. I can see how to thread in back through but cannot coil the string around, is this possible to do?
wind the coil 4 the string until it is taught hold it and thread line into it the recoil on the spring will pull it in a bit futery but persavere
Aug 17, 2010 | Yard Man Garden
The back of my Fender Stratocaster, where you put the strings in, is too far off from the back slot to put the strings in or out and the whammy bar won't screw in all the way
I'm guessing that in addition to your explanation, the guitar does not have currently have strings on it and you want to replace them. If so, this will fix your problem and is generally the best way to restring a floating bridge strat:
1) Remove the metal plate from the back of the strat. Inside you'll see the springs and the back of the bridge. Get yourself a thick piece of paper (or an ace of spades card like I do ;) and hold the guitar on your lap like you're going to play.
2) Gently push the back of the bridge up a bit and slide the paper/card in between the body and the back of the bridge on the front of the guitar. This will give you the room to get the strings through and slide the tremelo bar in correctly.
3) Restring the guitar starting with the low E, bringing it into pitch and then repeating in order with the other 5 strings. The card will fall out as the strings begin to put tension on the bridge. Replace the back plate and rock out vigorously.
Cheers,
NTIMID8
Dec 12, 2008 | Fender Stevie Ray Vaughan Stratocaster...
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
469 people viewed this question
Top Quad Cycling Experts
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
