I have a RCA MODEL #R52WH74. Everything works fine until the ambient temp drops to about 65 degress, then it will not turn on. if I take a hair dryer and warm up the switch area it will come on. can this be repaired? Thank you
  • 2 more comments
  • stoked4pow Jun 29, 2009
    I have a RCA MODEL #R52WH74. Everything works fine until the ambient temp drops to about 65 degress, then it will not turn on. If I take a hair dryer and warm up the switch area it will come on. can this be repaired?
    Thank you
    I have a RCA MODEL #R52WH74. Everything works fine until the ambient temp drops to about 65 degress, then it will not turn on. if I take a hair dryer and warm up the switch area it will come on. can this be repaired? Also it will stay on untill you turn it off. I never have had any problems with it shutting off by itself or turning it off normaly. Just turning it on.
    Thank you
    I have a RCA MODEL #R52WH74. Everything works fine until the ambient temp drops to about 65 degrees, then it will not turn on. if I take a hair dryer and warm up the switch area it will come on. can this be repaired?
    any more suggestions. thanks for the help thus far...
    Thank you
    Thank you.
  • 15,935 Answers
Sounds like a cold solder joint.
Heat makes the components expand, and then make contact. After cooling - the joint retracts, and contact is no longer made.
I would first do a cursory inspection of the power supply. However, Solid State repairs are never recommended unless you are properly trained - as there are potentially lethal amounts of energies stored inside that MUST be discharged before attempting any repair.
A good TV repair shop should be able to look over the board and have it repaired in less than 1 hour.
Between $50 and $75 is a good high estimate.
Thanks for using FixYa!!
Posted on Jun 29, 2009
  • 52 Answers
Most television have a automated temperature control system. If the TV is below a certain degree it might not turn on do to the fact that it might malfunction because of the low temperature. Nothing is wrong with your TV, its just working perfectly fine
    Genius:
  • 1,269 Answers
It could only be a bad fuse. Check the main fuse of the TV if it's slightly burned. Replacing that can fix the issue. If the power light keeps blinking, that's a fuse problem. If you can take it to the nearest electronic repair center, it wont cost you that much to fix it.
  • 10,594 Answers
Seems front switches got rust and do not work in lower temperature, requires replacement.
Please change key switches on front board of TV.
Thanks.
II have a model 5707591 side by side in my garage.as long as the ambient temp is 35-40 F everything works great.when it gets below that the freezer cant keep frozen.temps will rise to 25 F while the fridge...
the thermostat isn't cycling because it's to cold in the garrage,the machine isn't calling for cold air because the garrage is so cold so the fridge isn't gonna run until the temperature starts to get warm and then the fridge will start again to keep it cold.put some heat in the garrage and it will run fine
Feb 27, 2011 | Kenmore Refrigerators
10 yr old, sits in a garage. Worked fine until a
is the fan operating,if so then check your damper vent door that throttles cold air from freezer to refrige compartment they can freeze shut and a hand held hair dryer will thaw them out,then adjust its control to make sure the door moves when control is adjusted
May 08, 2010 | Kenmore 72102 / 72104
Tv's green light comes on then off three times
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Feb 08, 2009 | RCA Televison & Video
Ambient temp guage problems
The temperature sensor is located in front of the radiator on the passenger side. Replacements cost approx $25.00.
Jul 23, 2008 | 2000 Chevrolet Impala
No 120v to fan motor
It sounds as if this may have electronic controls on it. If so, the problem could be related to too low of an ambient temperature or too low humidity in the air. If this design has a temperature sensor built into it, you may be experiencing "hibernation mode", where the unit will appear to be dead, when it is actually awaiting the proper temperature to employ itself.
The following statement is a parameter for all dehumidifiers and some of the control issues may vary, but the theory is the same.
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Jun 02, 2008 | Kenmore 54351 Dehumidifier
Friedrich dehumidifier
Dave E. (Illeagle)
Jun 01, 2008 | Friedrich D50C Dehumidifier
Ebac 880 E
If your model does not employ a "Frost-Guard" the condition you describe will avail itself when the above parameters are not met.
Simply unplug, or turn off the unit, until the above parameters are met or exceeded.
Dave E. (Illeagle)
Jun 01, 2008 | Ebac AD850 Dehumidifier
Won't maintain a constant temp. Varies from +10 to -15
i doubt that.def sounds like bad cold control though,good news if your producing cold. Hair dryer good---- Ice Pick no good!!!
Feb 18, 2008 | Frigidaire 13 cu. ft. / 368 liter Chest...
Bad picture
My had the same problem except mine has turned yellow tint. I paid 65 dollars for someone to come and look at it and they told me that is was the Blue tube went out. They qouted me 700.00 to fix it.
Nov 27, 2007 | RCA (T120PAK12) VHS Tape (12-Pack)
D50c
Dave E. (Illeagle)
Aug 10, 2007 | Friedrich D50C Dehumidifier
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
