Question about Acer Aspire 5315 Notebook
No bootable device
I have an Acer Aspire 5315 and receiving the same error message,
Anyone have a quick answer / fix ?
Copyright (C) 2000-2006 Broadcom Corp.
Copyright (C) 1997-2000 Intel Corporation
All rights reserved.
PXE-E61: Media test failure, check cable
PXE-MOF: Exiting Broadcom PXE ROM
No bootable device -- insert boot disk and
press any key'
Thanks
  • Anonymous Mar 28, 2014
    cannot get acer to boot up
  • 3 Answers
Do you have the original cds for the computer? If you do, you will hae to download everything beginning with windows whatever you have. Unfortunately eveerything saved on your hard drive will be erased, but your computer should work after completing this.
Posted on Jun 28, 2009
  • Acer Master
  • 32,281 Answers
This error message can be caused by a faulty connection to the hard drive or a faulty hard drive or a faulty disk controller.
Go into the BIOS configuration to see if it has detected the hard drive, if it is not detected that is why the laptop won't bootup.
To confirm or check if the hard drive is faulty, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port (you may need assistance from a computer savy friend).
If this computer cannot see this as an external drive then it is faulty. If the computer can see this drive as an external drive and you can open the folders and files on the hard disk then the hard drive is OK and the fault is probably a faulty disk controller on the laptop. A faulty disk controller is part of the motherboard and the only fix is a replacement motherboard. This may not be a cost effective solution and it may be better to put your money towards a new laptop.
    Scholar:
  • 103 Answers
Enter the BIOS or SETUP (check for screen options Quick). Check is the hard drive is listed.
Look like.
If its listed, check for Boot order. If the hard drive is set to be the first device to boot and the OS doesn't not boot, consider windows is corrupt.
Posted on Jun 29, 2009
5 Suggested Answers
  • 13433 Answers
SOURCE: my acer aspire 5315 is stuck n i have no disk to reformat
the computer can't detect the hard drive to start from it or, then theres a problem with your windows. Use the recovery discs or windows setup cd to try to install windows to the computer again to fix the problem. Let me know how that goes. Thanks
Posted on Jun 07, 2009
elix0411
  • 3530 Answers
SOURCE: Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Apr 04, 2010
  • 162 Answers
Hi. I think the problem on this one is its either your Harddrive has already failed or your Optical Drive has a cd inside, so double check your Optical drive if there is a disc inside it. If not this issue is also with the operating system, you can try to restore your system by pressing the One Key recovery(OKR) button found beside the power button which has a logo of an arching arrow, but remember to plugin first the ac adapter on your laptop before pressing the One Key Recovery Button and also do not press the power button to turn on your computer because when you press the OKR button it will automatically turn on your computer and proceed with the recovery process. When it gives you some option you should choose One Key Recovery and then choose System Recovery, then factory default and from there it will guide you to the whole process of recovering your machine. If this doesnt fix the issue you could also try using the Recovery disc to restore your sytem t its original settings just like the OKR. Lastly you can contact the tech support dept. of Lenovo, they are open 24/7 and this the number to contact:
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope this helps
Posted on Jun 03, 2010
parrotheadpc
  • 2600 Answers
SOURCE: Broadcom UNDI PXE 2.1 v11 . 4.1
This is showing because the computer is not seeing the hard drive that contains the operating system. In some cases this is because the hard drive has come dislodged from the interface on the motherboard. Dells are good for this because the hard drive slides into the side of some models. Try reseating the hard drive and reboot. Your worse case scenario is that your hard drive has failed. The reason you are seeing the PXE-MOF etc. is that the laptop ias now looking for a network hard drive to boot from. It can't find the intenal hard drive so it is searching for other means to boot.
Posted on Jun 16, 2010
Can i download a bootable device for the acer aspire 5315
You can make a bootable disc or USB key by downloading an ISO of your operating system and installing it on the disc or USB key.
Dec 19, 2014 | Acer Aspire 5315 15.4-inch Notebook PC
No bootable device --insert boot disk and press any key
Sounds like your hdd has crashed. Look for a replacement hdd.
Feb 02, 2014 | Acer Aspire 5315-2326 Laptop Computers
Acer aspire 5253 error message no botable device after laptop was dropped on carpet
No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
Jan 10, 2012 | Acer Computers & Internet
Hi, I cannot boot my acer aspire 5315 laptop, No boot filename received. PXE-M)F: Eciting broadcom PXE Romm. No bootable device. Insert boot disk and Press any key. Please can you help. Mant thanks
It looks like your hard disk went invisible, and BIOS is trying all alternative boot options before it says that there's no boot device available.
I'm afraid that the most probable diagnosis is that the hard disk is broken; anyway you'll need hands-on service to establish what's wrong and what can be done.
Oct 18, 2010 | Acer Aspire 5315 Notebook
When I turn on my acer 5115 it says no bootable
it is possible that there is a mistake in somewhere in BIOS. when booting go to BIOS, and look for booting devices. As a primary booting device should be your HDD, or ODD first and HDD second.
apply these changes and see if the problem is fixed.
if it isn't, it is very likely that your HDD is not working anymore
Nov 14, 2009 | Acer Aspire 5315 Notebook
My aspire 5315 laptop is stuck on this sceen, broadcom undi pxe 2.1 v10.0.9 copyright (c) 2000-2006 broadcom coporation copyright (c) 1997-2000 intel corporation all right reserved. pxe-e61: media test...
Hello higgstwiligh,
The above message is mainly informational and doesn't necessarily indicate a problem. The acronym 'PXE' stands for Preboot Execution Environment. It's an environment to bootstrap computers using a network interface card. Usually the reboot is done by a remote computer on a LAN (Local rea Network). The Realtek NIC (Network Interface Card) somehow expected a PXE boot to be taking place when the computer was restarting. One solution is to restart the computer and go to the boot menu (F2 on some systems) and choose to boot from the master drive.
*Here's a link to a good article explaining what PXE is: http://www.search.com/reference/Preboot_Execution_Environment
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Nov 01, 2009 | Acer Aspire 5315 Notebook
My acer aspire 5315 is stuck n i have no disk to reformat
Jun 07, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315 will not boot up, indicating no bootable device
Sounds like you wiped out the harddrive try reinstalling the os if that does not work you may ned a new harddrive
Mar 16, 2009 | Acer Aspire 5315 Notebook
No boot disc
Yes bunnydawg could be indeed correct. Although also make sure you don't have a flash drive, external hard drive, or any CD/DVD left in the drive first. As they could try to boot from the device and fail (because they are not setup and formatted as bootable) and it will report the very same message.
Jan 30, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
3,361 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
