Problem with Brother MFC-9420CN
In the display window it says "Check Paper Size" "Reload Correct Paper"
We have letter size paper in there and that is the only type of paper we use. We have shut the machine off to try and reset it but that has not worked. After we take the paper tray out and reload it, it will print the same page every time we follow this step.
This happened on my MFC-9420CN. It turns out the there are blue tabs inside the paper tray that hold the paper in place. If the tabs are not touching the paper, you'll get this "Check Paper Size" error. The printer thinks that you have loaded a different paper tray.
Don P. Greensboro, NC
Posted on Jun 19, 2009
  • 1,113 Answers
Previous requested print job is sitting in print que is still trying to print, that job that was sent has a page size that is not letter. Open print que on computer....(start/control panel/printers and faxs - in there is driver for 9420, double click printers icon to open print que, delete docs in que. power off and then on printer.
Check default page setup in word or whatever you use also check settings on print driver by right clicking icon and properties.
Posted on Nov 08, 2007
Check paper size every time a fax comes in, reload correct paper
After you tried all of the suggested "fixes", contact Brother to see if there's a download that might address this issue.
Mar 21, 2014 | Brother MFC-9840CDW Laser Printer
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
Window says wrong paper size reload correct paper
its in setting on printer icon put it on full page.
Feb 26, 2011 | Brother MFC 6490CW InkJet Printer
My read out says check paper size, when i reload tray all it does is print out an old fax. I have letter in there and have gone though the trouble shooting in the manual.
Did you try clearing your remaining jobs? Fax, menu, arrow down to #2 (fax), menu, arrow down to #6 (remaing jobs)....
this helped me.
Apr 27, 2010 | Brother MFC-9420CN All-In-One Laser...
Won't let anything print unless it's on legal sized paper
Press the reports button and print the user settings, it shows the settings and also where the settings are. You press the menu button and scroll to general setup and scroll to paper size. There you can choose the size of paper you want to use.
Oct 13, 2009 | Brother MFC-9420CN All-In-One Laser...
My Brother MFC-9420CN printer is telling me to check the paper size. How do I do this?
Check to make sure the document your sending matches the paper size you have in your paper tray. The reason its telling you to check the paper is because your document size and paper loaded aren't matching
Jun 25, 2009 | Brother MFC-9420CN All-In-One Laser...
MFC -9420 CN Printer/Fax Scanner
I've seen this before...
The machine is calling for legal sized paper and it thinks it has it in the paper tray. Check the back stop that is inside the paper tray. It should be a green guide that is closest to you if you pull the tray out. You may have to lift up a flap on the end. Make sure that the paper stop is on the correct paper size for what is in the tray. Hope this helps. Let me know if you need any more assistance.
If this helps you please rate it as Fixya!
Nov 25, 2008 | Brother MFC-9420CN All-In-One Laser...
Reload paper error
Listen for the paper tray is popping up when you push it in.
Remove the paper tray completly and look for paper in the cavity.
Jun 24, 2008 | Brother MFC-8220 Fax
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
505 people viewed this question
