Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My went black in the middle of the screen in an area roughly equivalent to the full screen mode. The area on either wing still had picture. Sound was fine. I changed the input from HDMI4 to HDMI1 and everything works fine. Question is, is there a problem with the HDMI connectors that needs repair?
  • 197 Answers
No your closed caption is turned on it will only do it on certain chanels. turn it off on the tv set
Posted on Jul 01, 2009
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Screen went black with a vertical rainbow line down the middle
Failue of the vertical section, could be the drive, the power to the section or even some discrete componets. Unless you are familiar with electronics , get some help to ceck out on these circuits, could not be major but to get themain culprit will require good probing.
Jun 29, 2010 | Panasonic PT-56TW53 56" Rear Projection...
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
Screen black no sound or picture with line in center
this is a common problem,the vertical hold has been damaged.dont leave the teli. on,the white line will burn the middle of the screen and leave a black mark. You need a new integrated circuit(i.c.) for vertical hold.
Mar 17, 2009 | Televison & Video
It only shows a black screen
I was having the black screen problem intermittently (of course when you really want to take a picture quickly). I downloaded v1.1 of the firmware from olympus (via the Olympus Master 2 program) and the black screen problem has not reoccurred yet. Hasn't been tested over a long period of time yet, but that seemed to fix it.
Jul 12, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Magnavox Mod. # HD 2715 C 202
Your set in in closed caption mode text 1....Go into your menu and un-do the closed caption mode.
Feb 18, 2008 | Philips Magnavox 27MS343S 27" TV
Screen went black but i have sound
i was watching tv and in the middle of the show the screen went black, but there still was sound. i turned it off thinking it was the cable for that program and when i turned it back on several hours later it still had no picture all connections are good.
Jan 02, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Black box in the middle of the screen
The closed caption is turned on. I don't have the schematic in front of me, so, I will wing it. There may be a button on the remote that says CC, if so then use that button to turn it off, if not then go to the service menu and you may have to search a bit. Either way it's an easy fix and you can do it yourself. If you can't find it, then, reply and I will give better instructions when I get into my shop next week.
Feb 17, 2007 | Mitsubishi CS-31205 TV
Black screen in middle of picture
go tothe menu, caption, take it off the text mode. this should solve your problem
Nov 13, 2006 | Toshiba 35A44 35" TV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
