Question about Haier HWR08XC7 Air Conditioner
Almost same problem but mine says E0
My AC will start up and the shut off and displaying E0 and then shortly later it will start up again and repeat itself
  • Juan Carlos Cabrera
    Juan Carlos Cabrera May 11, 2010
    Your Air Conditoner makes a Humm sound then stop before displaying E0? You see changes in the room lighting?
  • J Easley
    J Easley Jul 06, 2018
    I rest the E1 error code the E0 is the code that popped up after reset
    Scholar:
  • 70 Answers
Try washing out condencer coil.
Posted on Jun 29, 2009
I have this issue, my teac ag d7900 which itself off to standby and when I switch it "on" again, it says protect and shut itself down again
Right. This means that either you have a short in your speaker cable somewhere or the short-detector circuitry inside has problems. Disconnect all speaker cables and turn the receiver on. If the symptom goes away, turn the receiver off again and connect one of the speaker wires. Repeat until it starts to go into protect again. When it does, the last speaker you hooked up has a short somewhere in the wire.
If protect always comes on, you'll need to get the unit serviced.
Jun 28, 2015 | Teac Audio Players & Recorders
2003 mercury sable, AC will blow ice cold until I spend too long sitting in traffic then it starts to blow warm, if I shut AC off and start moving after about 5 minutes I can turn it back on and it gets...
It's gathering frost inside. When you turn it off & drive around for a short while, it defrosts & starts working again.
I'll bet when you park it, you find a pretty large pool of water under it half an hour later, don't you?
Sorry, that's the nature of the beast - it's worse in humid weather, not so bad in dry weather. Pretty nearly all cars (with AC) do that unless the AC is designed oversized.
Jul 26, 2014 | Cars & Trucks
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
HP note book 2000-350 US no display it's black and can't start up
Try the guys at: http://www.generalsystemsconsulting.com
They are muuuuuch cheaper than HP and do a good job. They will fix it and ship it back by Fedex or UPS
Mar 10, 2012 | HP Computers & Internet
Ac blows warm air after it cool the cabin
My Durango did the same and it was a high pressure switch bad. If you stand at the front of vehicle it is located on the left side next to the radiator support by the radiator. There is a rubber flap you may have to lift to see it. Switch was a dealer item $ 40.00 I have not had no more problem out of it.
Mine would cycle on and about the time it would get cold the compressor would shut down, it may start a little later or it may be the next day before it would get cold again and then would shut down.
Jul 17, 2010 | 1999 Dodge Durango
Display shows E0 F2 after pressing start and cancel at same time. No other buttons work. Stovetop still works.
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 14, 2010 | Whirlpool GY398LXPS Electric Kitchen Range
On the PC785, I tried shorting the JP1 & JP2 solution.
Hello sir; If you repeat same shorting procedure still don't work then you have to check heater lamp or thermos fuse brown.
Aug 28, 2009 | Canon Office Equipment & Supplies
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Haier HWR08XC7 Air Conditioner Logo
407 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
