Question about AmcorAire UCHW-H24AF2 Split System Air Conditioner
Aos241hx trouble code p4 and p8/ unit just installed / runs fine until direct sun hits unit / resets after 15 minutes / runs untill temperature change and sets code p8 / restarts after 15 minutes down time and works normall untill temp change
2 Suggested Answers
SOURCE: amcoraire / aos241hx / code p8 / unit shut down will not restart
for all error codes. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Posted on Jul 13, 2009
2011 kia runs. About 8 blocks then died. Won't start. Back. For about 15 minutes
Had a motorbike with the same condition. That was caused by insufficient air coming through the air filter. The techo drilled extra holes in the air filter box. No more trouble. Otherwise, this is a fuel problem - fuel filter, injectors etc; But do not rule out faulty computer controller box.
The 15 minutes??? Does it then run all day??? until left standing overnight? Could be fuel related, air mix or temperature related.
Jul 12, 2014 | Cars & Trucks
I have lost my service Manual for my NEC 6847 Air con unit & need to download one so that i can figure out how to get the heat to work
Make sure the remote control 'Mode' setting is on 'Heat', usually an icon that looks like a small sun. Then increase temperature setting until unit switches on. Can take 7 minutes or so to give any warm air flow, but if nothing after about 15 mins, then you have a problem. - Rick
Jun 12, 2011 | Heating & Cooling
Scooter tuns fine until left in the sun. I know that mine had a recall on the fuel pump seal and that has been taking care of except the problem still occurs. I have taken it and it is currently at the...
Hi, Jltaylo7176 some bikes get "Sun Stroke" after running fine in the morning then shut off and parked in the sun for a couple of hours on a hot day. You get back on the bike hit the starter button and nothing happens or the engine turns over but will not fire. Then you put the bike in the shade for 20-30 minutes and it fires up no problem.
The primary reason for this phenomenon is faulty wire connections in the Starter and/or Ignition Circuit. You may have a wire connection/component that makes just enough contact when cool to start and run the bike, but when parked and exposed to direct sunlight heat causes expansion and creates an "OPEN" in the circuit not allowing the bike to start. You move the bike into the shade for a few minutes, the temperature goes down allowing the connection to contract and make better contact and suddenly "it's a miracle" the bike starts. I know what you're thinking that Gremlin could be anywhere, and you would be right in that assumption, you can take your bike to a dealer, spend tons of "DRACHMA" only to receive validated nervous emotions the next time you park in the sun, then 1 week later it doesn't start. Start by doing a ground check:
Check the battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Check all common grounds for the same suspects.
The secondary reason your bike may get "sun Stroke" is vapor lock although this is a rare scenario it does happen.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bike won start after parking in the sun no one can help me
Why won my motorcycle start in the afternoons
Trouble Starting Engine
ybr 125 Starting Problems
r6 Wont start after sitting in the Sun 5mins
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 23, 2017 | Yamaha Agusta F4 R312 1 plus 1 Motorcycles
I have a 24 ton mini split, that has never worked correct. It used to blow cold air, but only for a little while, then it set error codes including p4, and p8. The heat functioned used to work ok. Now it...
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor. Due to non condensable gas/over charged/condenser dust blocked.
For non condensable gas, remove gas and flush out and then recharge gas./remove over charged gas/clean condenser coil
Aug 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Amcoraire / aos241hx / code p8 / unit shut down will not restart
Jun 30, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
P8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Runs until it gets to operating temperature then dies and won't start
No I haven't fixed the problem yet but don't think I want to pay not knowing whether or not anyone can help me. Thanks anyway.
Oct 04, 2008 | 1992 Oldsmobile Cutlass Supreme
Temperature Control not working on LG fridge
It is an error code. The thermal fuse in the freezer section has gone. It has to be replaced. To get by in the short term, uplug the unit for 15 minutes, then plug it back in. It will run until it hits the defrost again (approx 5 hours) Part location is 401A and part number is 6615JB2005C. It is easy to change once you get the back cover off. Plug in part.
Sgt 48
Jun 07, 2008 | Refrigerators
AmcorAire  UCHW-H24AF2 Split System Air Conditioner Logo
154 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
