Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
My maytag wide by side keeps frosting up .
The back of the frezer frosts up and no air goes to the fridge. I have defrosted it twice already ,and cant fide any pluge in the drane. a service man said it could be from someone leaving the frezer dore open.thats non hapining.. could you help me..thaks mark.
  • msbates66 Jun 28, 2009
    how do i check the thermostat or defrost timer
  • msbates66 Jun 29, 2009
    problum solved thanks for your help.replaced defrost acuater assy.
    Sergeant:
    Champion:
  • 235 Answers
You might have a bad thermostat or defrost timer has gone bad.
Posted on Jun 28, 2009
  • Gilbert Martinez Jun 29, 2009
    Find the timer and turn the little knob until it activates. Activation starts and defrost begins. On the t-stat, remove it from the back of the fridge via the inside of the fridge(back panel)check for continuity with a meter on ohms. Place t- stat in freezer for a few minutes and then check for continuance. No continuity means a bad t-stat. Oh, if timer activates manually, replace it.
Freezer side is cold but the fridge side is not getting cold
Luispinto243 --
The heat exchanger is in the freezer side of a refrigerator. If the cold air pathway has gotten frosted-up, or the blower is not working, the fridge side will get warm. If possible, fully defrost the unit and the frost/ice build-up will thaw-out and the fridge will start working again. Adjust the thermostat to the energy-saving position. Trying to lower the temperature will not fix the problem. If you are still having problems, write back. -- SWT
Aug 22, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
My freezer cools properly but my refrigerator is not staying cool .its kenmore and bought from sears 2004 $1000. side by side refrigerator
Quick temporary fix - defrost the freezer (inside frezer lower back) it is probably full of frost/ice - this prevents air flow and therefore no air enters fridge side. common failure due to bimetal defrost thermostat failure ($20) - replace this part for a permanent fix - also advisable to swap out the defrost timer at same time
Aug 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The refrigerator is not staying cold. the freezer works fine. we tried the settings to no avail. any advice?
Quick temporary fix - defrost the freezer (inside frezer lower back) it is probably full of frost/ice - this prevents air flow and therefore no air enters fridge side. common failure due to bimetal defrost thermostat failure ($20) - replace part for permanent fix
Aug 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge side not working freezer frost on back at first now not freezing hardly at all
If you still have the frost build up on the back wall of the freezer, your problem is in the defrost circuit. You'll find a bad heater, terminator or control.
Also verify operation of the evaporator (freezer) fan.
Apr 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag wide by side not cooling. just prior to this frost build up on top of freezer. Compressor not running.
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. My coil was solid ice.
Apr 05, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
My freezer works fine, however my fridge is not cold. It seems as there is no air flow in the fridge. I have checked behind the crispers to ensure nothing is blocked. I have a Maytag msd2734ge, wide by...
check in the freezer side and look at the back wall and see if there is any build up of frost, your coil may be block, so no air flowing through the coil, your unit may not defrosting, you need to check the defrost heater,the defrost timer or the defrost thermostat one of these part can be defective
Dec 11, 2008 | Maytag MSD2734GE Side by Side Refrigerator
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
369 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
