Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 TV just turned off and doesn't turn on???
My tv just turned off and now it doesn't turn on ? what happened? Don't have the extended warranty ?can anyone help
  • 1694 Answers
SOURCE: RCA D52W20
Check for smooth,accurate adjust of RGB focus located up front behind speaker grill.If jumpy or inaccurate,replace RGB adust block.If that is not the cure,you may have bad CRT(s).
Posted on Oct 09, 2007
SOURCE: MY RCA TVE WONT TURN ON
Did you change your battery from the remote?
Posted on Dec 02, 2007
  • 1030 Answers
SOURCE: 52inch RCA model#D52W20 tv
the d52w20 rca chasis itc222 can be difficult to troubleshoot sometimes. there a few things you can assume at this stage. ONe it is NOT the fuse. The processor in this set is seeing a voltage or saftey shutdown issue. and is shuting the set down for saftey. THis is where the troubleshooting begins. High voltage or overcurrent conditions are generely the problem. \technicians have speceil computer diagnostic equipment that can read error codes in the processor. much like in a car. but without it yo0u pretty much have to check things like horizontal ouput transitor.
Posted on Mar 16, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Posted on Jun 29, 2008
Slinteriors
  • 8617 Answers
SOURCE: have a 52 inch rca
replace the flyback, very easy repair. You need flyback 259296 you can getone at the following link with free step by step instructions with pictures. heres the link read their reviews.
http://servicemanuals.vstore.ca/
Posted on Jan 22, 2009
Tv goes off then comes back.
Sounds like you might have a cold solder or bad connection at the power supply. Don't fool with this yourself. TV's today are very delicate and you need to take it to a professional. It probably won't cost you much. Let him take a look at it, give you a price for repairs, then let him fix it for you.
Jun 14, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA modelD52W20 Problems turning TV on when it is cold or for the first time after being off for an extended amount of time. The green lite comes on ,stays on a few seconds and goes out. After continueing...
well usually what works for me is a small heater on near the tv or just keeping the room above 65 degrees. There is a way on some tv's to turn off the power saver and that will keep your tv warm. But on others you cant turn it off so you have to deal with the heater or keeping the room warm cause that tv wont turn on for anything exept if its warm....
Dec 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have a 52 inch rca d52w20 rear projection tv, the tv was on then it just turned off..attempted to turn it back on and heard a sqeaking noise and tv will not turn back on.. please help..
Jan 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv will not stay on
In these older CRT based TV's the first thing to usually go out is the power supply. I had the same thing happen to me were the TV would turn on then turn off a few minutes later until it did not turn on anymore.
Unfortunately if you do not have a extended warranty then it is usually expensive to fix and you may be better off with a new TV. When I got my TV fixed under the extended warranty I was told it was a $500 service and at that time the TV was not worth that much.
I wish there was a simple answer but alas this is probably the problem.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20 52 IN
Bad capacitors on Power/deflection board cp150,cp114,cp120 capacitor cp 150 2200uf 16v, cp114&cp120 220uf 35v
Dec 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
MY TV WANT COME ON
go to radio shack or target before they close and buy an rca brand universal remote you wont even have to program it to your tv good luck
Sep 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca d52w20 52inch tv doesn't want to turn on
Well not knowing this particular unit myself, i would strongly suggest troubleshooting the users manual, which can be downloaded here.
http://tv.rca.com/en-US/UGConfirm.html?modelno=D52W20
Jan 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dec 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
228 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
