Question about HP PhotoSmart 7350 InkJet Printer
HP 7350 Printer cartridge is stuck, just put in new cartridges...
I put in new cartidges, sprayed for dust, cleared and reset the paper stack and nothing.
SOURCE: cartridge cradle is stuck
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
Posted on Dec 31, 2007
SOURCE: printer cartridge cradle is stuck-hp photosmart 7350
I just had the same problem...and this is what I did to get it working...
Turn off your printer. Open the top. Push the cartridge thingie off to the side (if possible) and then take QTips and cleaned the silver bar the cartridge moves on. Got a lot of ink off of it.
Should run after that.
Posted on Jul 12, 2008
  • 7 Answers
SOURCE: Magenta Ink cartridge is stuck in Xerox Phaser 8550/8560
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc fault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
michael_grey
  • 365 Answers
SOURCE: MP610 PRINTER ERROR 6A00 LIGHTS FLASHING
You can try to reset it back to factory by removing the printhead and all cartridges.
Power off the unplug from wall for 30 min.Reverse procedure and see what happens.
From what I am reading is the carriage will not lock on the left!
Correct?
Try this and let us know.
Posted on Aug 15, 2009
  • 3 Answers
SOURCE: Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Posted on Oct 09, 2009
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at http://www.okidata.com/ .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
Wont print ready light and alarm light flashing
When the printer "Ready" and "Alarm" LEDs flash as shown, please check the following points:
1.Paper Jam: Clear the paper jam referring to "How do I clear paper jams?"
If the printer does not automatically resume printing, press the control panel button.
2.No Paper/ Misfeed:
-The paper cassette may be out of paper or not properly installed.
-If it is empty, load a new stack of paper into the paper cassette.
-If there is paper in the paper cassette, make sure it is straight.
-If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
-Reduce the amount of paper in the paper cassette, and then try again.
-Make sure you use paper that meets Brother's recommended paper specifications.
-Reinstall the paper properly, and then press the control panel button. The printer will start printing again.
Dec 06, 2010 | Brother HL 1430 Laser Printer
Paper jammed - how do I get it out?
  • Follow the below steps to clear the paper jam
    Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
  • To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
  • For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
  • Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
  • Try printing another document.
  • Nov 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    How do you reset an H5-01 error code on Sharp Color MX2300 Copier.
    Hello
    Most error codes can be cleared by removing the paper jam and then rebooting the machine. When an error code occurs, make a note of the code and then follow the instructions on the control panel for clearing it.
    Paper jams can be caused by a variety of issues in the copy machine, but jamming can commonly be caused by improperly loaded paper in the trays or dirty paper feed rollers.
    If you get repeated paper jams, remove the paper from the trays and inspect the stack. Look for folded corners, especially on the bottom of the stack. Fan the paper thoroughly and then reload the stack into the tray. Check the paper guides to ensure they are not too tight or too loose. Both conditions can cause paper jams.
    If you can see the paper transport rollers by opening the ordinary access covers and panels inside the machine, cleaning them might help reduce paper jams. Shut the machine off and unplug it, then take a soft, lint-free cloth dampened with water and wipe those rollers off. A buildup of toner and paper dust can cause them to slip while transporting the paper.
    Oct 21, 2010 | Office Equipment & Supplies
    Paper jam when there is no paper... how do i clear it
    There is small switches at the entrance and the exit of paper, this to detect there is paper, make sure those switches are not broken,stuking, or make sure nothing stuck there( small paper, dust) clean that part, put the machine off and on will reset it.
    Thanks for using Fixya
    Oct 14, 2009 | HP Officejet J3680 Multifunction Printer...
    Water trickles out of sprayer head on pull out faucet.
    Hi crossroadsjm,
    I'm Harvey the Master Plumber.
    Your problem is: soaked in vinegar water but did nothing. took off spray head from hose and the water stream is very small in diameter. only 1 year old faucet. could cartidge be bad or clogged? water pressure in rest of house is fine.
    It is very possible that some debrie has come up in the water and is partially clogging the faucit. For this you would have to turn the water off and disassemble the parts clearing all the small passages, a bit of wire or paper clip works. Perhaps for a pro? If you like you may choose to utilize our Repair Directory.
    Feel free contact me again!
    Please give me a rating here at fixya.com before you sign off
    Thank you,
    Harvey your Master Plumber
    Oct 14, 2008 | Price Pfister 532-7PCC Marielle Pull-Out...
    Hl 2040
    You must have refilled the first (starter) cartridge or didn't reset the toner reset lever. There is a reset lever on the left side edge of the cartridge. Look at the left end of the cartidge (not the fill cap end) for a round white gear end and a white lever in a hal moon shaped slot. If you can see only the round white gear and the hlf moon is emty of a white lever, it's a non-restting starter. If you have two white spots we will be addressing the one in the half moon slot. The used cartidge will have the lever at the "3 O'clock" position. To reset the cartridge as new you must remove the two screws on that end cap and move the lever to the "11 O'clock" position. Put the scews back in and reinstall in the printer. The sweeper lever will turn in the machine and reset the toner count.
    ***Important For Brothers**
    Make sure when refilling that ALL WASTE TONER is completely cleaned out of the cartridge before adding new toner to it. Brother re-uses its old waste toner and over time the toner hopper gets contaminated with paper dust and too much old toner inside causing them to fail. It you just add toner to the cartridge without thoughly cleaning out, you will soon have a bad cartridge again. You'll see it when dumping out the old as white specks in the toner. That's actually contamination from paper dust and talc from the paper.
    Hope that helps you.
    Jul 27, 2008 | Brother HL-2040 Laser Printer
    HP Deskjet 3940 (Paper Jam)
    I have a HP Deskjet 3940 printer. And similarly to this problem here I had a paper jam that would not clear, despite removing all the paper that was stuck in it, and following all 4 steps stated on the HP website. Such as taking the back cover off and blowing dust away and turning it off and on, etc.
    None of these steps worked for me and consequently I couldnt get any new jobs to print - kept saying 'paper jam'. I was about to head down the shop to buy a new printer when i tried one last thing, which HAS fixed the problem!
    I put in a large stack of paper onto the feeder. and then pushed it forcefully in and out repeatedly. To my amazement this has solved the paper jam. As a very last resort, might be worth trying this?
    Jul 25, 2008 | HP DeskJet 3940 InkJet Photo Printer
    Lexmark 5250 printer
    Before you put papers in tray it must reshaple make separate each other , to delete the message "off the power " on again to continue printing.
    Dec 10, 2007 | Lexmark X5150 All-In-One InkJet Printer
    HP PhotoSmart 7350 InkJet Printer Logo
    115 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
