Question about Dometic RM2652 Refrigerator
I have the Dometic RM2652 model, the freezer only gets to about 40 degrees and the frigerator gets to about 50. there is no temp control on the inside of the unit. What is the problem? It is getting worse the more we use it.
  • 15,935 Answers
Your Thermostat has failed.
Unfortunately - there are no online references to find schematics or parts. Your best chance for repair is your local appliance repair shop.
THanks for using FixYa!!
Posted on Jun 28, 2009
RM2652 Dometic refrigerator/freezer
see inside if fridge has temp senor on back metal heat sink
Mar 13, 2018 | Dometic Refrigerators
Freezer doesn't get cold enough (about 20 degrees) & refrigerator is about 38 degrees
check gaskets if ok lower the temp sensor on fridge coils to get colder
Jun 13, 2014 | Dometic RM2652 Refrigerator
My rv refegerator freeezes as if it was the freezer as low as twenty degrees any help would be appricatedThanks Brian
sounds like you need a new thermostat. refrigerator section should be between 34-40 degrees. is the temperature in the freezer ok? what setting do u have the thermostat set at?
Feb 04, 2011 | Dometic RM2652 Refrigerator
Dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Jul 23, 2010 | Dometic RM2652 Refrigerator
Dometic 2852 freezer gets cold but refridge does not
If your freezer is getting down close to zero degrees (F) then I doubt that your refrigerant is low. The most common cause of the refrigerator section not getting cool (approximately 40 degrees (f)) is a fan that pulls the coils in the freezer into the refrigerator has failed. A very common failure of a cheep little fan motor. Normally that fan is behind a panel in the freezer section at the bottom. Determine where the cold air in the refrigerator section normally enters and the fan will be above there.
Aug 11, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652
If your power supply changes such as shore to gen or any other source change the light will come on Try resetting If it continues you may need a voltage monitor to verify your not having other problems
Aug 18, 2008 | Dometic RM2652 Refrigerator
Poor cooling fridge
Small slide control inside of the fridge. Think of this as your knob control on house fridge. Slide it up and down the silver coil to adjust temp in the lower unit.
Aug 15, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
46 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
