Question about RTO Atwood Water Heater - 6 Gal LP
Burner lights but will not shut off. then pressure
I have a Atwood gas water heater model # G6A-8E.The burner lights normally but after a short while the pressure release valve starts to leak as the water heats up and the burner will not shut off. The leak starts off as small drops of water to water flowing quickly through the valve.Help!!
I am having the same problem with mine changed the pressure relief valve and the ECO \ TSTAT but still gets extremely hot can't even touch the water what else could it be
Posted on May 02, 2010
  • Roy Osborn Jun 10, 2013
    What did you do to solve this problem? I am having same issue.
  • 160 Answers
CHECK TO MAKE SURE THE WATER TEMP IS AT THE NORMAL OPERATING RANGE. USUALLY AROUND 120-130 DEGREES. IF IT IS, CHANGE OUT THE PRESSURE RELIEF VALVE. IF THE TEMP IS OUT OF SCALE, CHANGE OUT THE ECO AND TSTAT.
Posted on Jan 09, 2010
Atwood g6a 8e
The yellow is caused because the flame does not have enough oxygen. Per your explanation that is being caused because the exaust is not working. Fix the exaust problem and it probably will begin opperating properly.
Mar 23, 2014 | Water Heaters
I have a 1997 Fleetwood Bounder with an Atwood G6A-8E water heater. My pressure relief valve was leaking heavily, and I think it shorted something out, because now my electric igniter will not light the...
Have you checked your fuses? there should be a removable cover to pull off there will be a fuse in side that powers the self ignite..can you take a pic of the panel and post it or send it to my email?
Nov 30, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have an Atwood water heater model G6A-8E. When
If this model has a thremo couple you might want to check it. It sounds like that is the problem.
Jun 07, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have a G6A-7E electronic ignite water heater.
Make sure propane is on and getting to your stove burners ok, first, then try switching it back on. If it fails to ignite, shut switch off and try a couple of times, if still no ignition, get back to me.
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
Have an G6A-8E Atwood water heater. It Starts fine and shuts down after a couple of seconds. I can see the diode in the control board continue to spark after ignition I replaced the igniter.
If it has the little thermal cut-off in power wire to thermostat (has a little plastic jacket over it) try removing it, and connect female spade from power wire, directly to male spade on thermostat, and see what happens. Also, make sure electrode is positioned in flame good for flame sensing properly.
May 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood Water Heater - 6 Gal LP Logo
515 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
